B18B1 Turbo Question?
Old Feb 14, 2012 | 02:41 PM
strykr89's Avatar
Default B18B1 Turbo Question?
I currently have a 94' Integra with a B18B1 and am wondering if the turbo I have sitting in my basement will work?
It's a Garrett turbo, the compressor A/R .50 and the turbine is A/R .96 w/ T4 split flange.
The compressor has a 3" intake and the turbine has a 3" outlet.
I'd like to know if it will work with my teg? And what you guys think it would spool at? (My guess is 4-4.5k)
Old Feb 14, 2012 | 03:14 PM
Turbo-LS's Avatar
Default Re: B18B1 Turbo Question?
Any turbo will work, that a broad question. Will it work well probably not. Low revving engine with a big t4 turbine housing. Sell it and get a properly sized turbo
Old Feb 14, 2012 | 03:24 PM
DirtyDA9's Avatar
Hot side is too big for that engine
Old Feb 14, 2012 | 03:32 PM
Gchois123's Avatar
If u can buy a smaller hot side that turbo will be fine
Old Feb 16, 2012 | 09:37 PM
strykr89's Avatar
By too big in what is it too big? Because I'm not looking for a turbo system that will kick in at 1500-2300 I'm looking for one that only delievers the power I want when I really gas it (the track) other then that low boost is perfect. I just want to know at what rpm do you guys think it'll be building at? My guess is around 4000-4500 which leaves me with 2500-3000 until redline, and after that the no lift shift will help the boost stay built while I'm shifting down the track.
Old Feb 16, 2012 | 09:47 PM
TheShodan's Avatar
Moderator
Something like that will more than likely only give you about 1000rpms of actual use of the turbo. Until we see some pictures of the compressor and turbine wheels, we can't be totally sure. but I can tell you on a B18B1 for what you're looking for, this will perform badly for you and you'll hate turbo life with such a large turbocharger on your LS engine, regardless of what turbine housing you switch to.
Sorry, just truth.
Old Feb 16, 2012 | 10:15 PM
yungkhmer's Avatar
yea just like my setup. Turbo is wayyyyy to big. i hit full boost in my b20/built ls head at 6k and my redline is 8k. You should get something a little smaller. which is what im trying to do right now. i want power from 4500 to 8k.
Old Feb 16, 2012 | 11:08 PM
DirtyDA9's Avatar
Your looking at it spooling at about 6,300 rpms, with leaves you with no room. Might as well be NA then.
Old Feb 17, 2012 | 06:57 PM
strykr89's Avatar
What size turbine should I get then to have a 3500-4000 spool?
Old Feb 17, 2012 | 07:05 PM
TheShodan's Avatar
Moderator
The question is... What turbo do you have NOW? The housing sizes are not nearly as important as the wheels you have within the housings.
Old Feb 17, 2012 | 07:10 PM
strykr89's Avatar
That's part of the problem.. The ident plate broke off.. All I know it that it's a Garrett and the ar sizes so far
Old Feb 17, 2012 | 07:24 PM
TheShodan's Avatar
Moderator
you need to TAKE THE HOUSINGS OFF, and stop worrying about plates. Start measureing. Then you know what you're working with. In millimeters, please.
Old Feb 17, 2012 | 07:31 PM
strykr89's Avatar
Not worried about the plate, and my plan is to take the housings off. Then this way I can check the trim and also inspect the blades properly
Old Feb 17, 2012 | 08:38 PM
DirtyDA9's Avatar
I doubt this man owns a micrometer...
Old Feb 18, 2012 | 11:50 AM
Schister66's Avatar
Man U FTW
Without knowing any more about it, I'm siding with TheShodan...you're better off selling it and buying something that actually fits the engine's size instead of wasting time on this one. A simple T3/T04e 50 trim is only ~$4-500 used and would be a much better match for your setup
Old Feb 21, 2012 | 08:08 AM
strykr89's Avatar
Actually I do own one thanks. Just because I'm new to turbochargers, doesn't mean I'm new to tools and building cars.
I'm probably going to get a new one, was just trying to see if there was any cheaper options with what I have..
94integra-nade
Dec 8, 2009 06:06 PM
Jeanious
Oct 11, 2008 05:02 PM
Terrabomb
Jul 13, 2004 06:28 AM
1BadDC2
Mar 20, 2004 02:49 PM
TurboT
Dec 13, 2001 09:50 AM
