1st time building engine, couple questions
Old Mar 4, 2012 | 06:10 PM
uscivicmc's Avatar
Default 1st time building engine, couple questions
hey guys, i just picked up an complete ls block. i'm ordering a set of manley h beams and wiseco pistons. as far as having the rotating assembly balanced, what do you guys reccomend? is it necessary?
Old Mar 4, 2012 | 06:14 PM
MiraiZ's Avatar
Default Re: 1st time building engine, couple questions
depends on what you're going to use it for, you HP goals, and your budget. Please elaborate on what you intend to get
Old Mar 4, 2012 | 06:16 PM
uscivicmc's Avatar
i'd like to get around 450-500 on e85.
i've got a stock b16 head gsr cams, i'll be putting some supertech springs in it as well.
i'm using a forged performance ramhorn with an holset hy35 turbo and a 38mm gate
and my budget isn't very high at all, but if its something that is really really worth doing, then i'll bite the bullet and spend the money
Old Mar 4, 2012 | 06:20 PM
TheShodan's Avatar
Moderator
You could keep the stock assembly in that LS block for what that HY35 can do (about 50lbs/min) and 400whp. But, I've always believed if you're getting new rods and pistons to be set with the block, there's nothing but good things that come from a bit of extra insurance by balancing the assembly.
Old Mar 4, 2012 | 06:37 PM
uscivicmc's Avatar
well i'd like to make +/-500 with this motor, and i'd like to have some room to make more power if i wanted to without building another motor if that makes sense
Old Mar 4, 2012 | 07:04 PM
EG1834's Avatar
I wouldn't worry about it.
Old Mar 4, 2012 | 07:12 PM
Spawne32's Avatar
i always have the rotating assembly balanced when rebuilding an engine, its good insurance especially if your gonna beat the **** out of it. I just had my whole rotating assembly on my new b20 build done. Cost about 250 for the balancing.
Old Mar 4, 2012 | 07:13 PM
DirtyDA9's Avatar
If you want it to last at 500+hp, look into sleeves. And yes you should get the rotating assembly balanced.
long beach dc2
Sep 24, 2012 05:38 AM
loudassVTEC
Jun 4, 2006 05:45 AM
Spudddy
Mar 16, 2003 10:13 AM
Speedz
Dec 18, 2001 06:57 AM
integra81
Oct 29, 2001 09:49 PM
