Identify This Turbo... HELP FAST
Old Mar 10, 2012 | 12:18 AM
hmong337's Avatar
Default Identify This Turbo... HELP FAST
What do you guys think this turbo is? I'm looking to buy this. I can't seem to find much info from going off the pics. The turbine housing has 20357 and 20358 written on it. That makes it either a 0.48 a/r turbine or a 0.63 (most likely a 0.63 if it was ran on an MR2). And the compressor side has a 4" inlet A/R 0.70 housing but I'm sure it's a T04E sized turbo... No idea on trim. The seller pulled this setup off a car. He's a credible seller. Just doesn't know what this turbo is. Help out if you can. THANKS!
...this will be for my MR2.
Old Mar 10, 2012 | 04:05 AM
Slacker93eg's Avatar
10 Year Member
Default Re: Identify This Turbo... HELP FAST
I'm guessing it's a garrett
Doesn't it say A/R .70 right on the front?
Old Mar 10, 2012 | 04:40 AM
Turbo-LS's Avatar
Pull the housings off and measure the wheels. It looks like its a turbo in need of rebuilding thats for sure.
Old Mar 10, 2012 | 05:17 AM
TheShodan's Avatar
Moderator
Definitely needs its journal bearings and rear ring seal replaced. Reputable seller he may be, but the turbo needs repair. (please don't ask how much to do a repair based upon pictures, as it must be sent in to a reputable shop to be inspected.
Old Mar 10, 2012 | 09:29 AM
hmong337's Avatar
Well it's definitely cheap for a reason. $200 for the entire turbo kit w/ downpipe, wastegate, air filter, minus the oil lines.
But I already told him that I'm taking a pass on this. Looks to be more work than it's worth. Plus, I don't even know the specs of the damn thing...
Thanks.
JaGuAr81
Dec 12, 2012 03:12 PM
jv88_dc2
Jul 4, 2011 03:14 PM
boosted ej8
Feb 4, 2009 06:27 AM
NuclearB18B
Jul 13, 2003 02:20 PM
PROFILES2000
Mar 8, 2002 07:51 PM
