valve spring specs
Old Nov 25, 2004 | 08:40 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default valve spring specs
does anyone have a link to honda valve spring pressures?specifically all b-series.just curious.thanks!
Old Nov 25, 2004 | 06:57 PM
25 Year Member
Default Re: valve spring specs (turbotypeR)
nobody?
Old Nov 28, 2004 | 05:26 PM
25 Year Member
how about-does anybody know gsr and type r spring pressures?
Old Nov 29, 2004 | 08:28 AM
RyanEJ8's Avatar
Bump, but I'd also like to know the SOHC specs. Are they listed in Helms? Mine is in pdf format and I can't really look through it right now. At work.
Old Nov 29, 2004 | 10:07 AM
rtype11's Avatar
did this years ago , forget but think it was around: seated pressure might be around 130lbs, open might be around 150lbs at proper installed height, thumb rule is add 1 lb pressure to the spring per psi of boost you plan on running to compensate for float.
Old Nov 29, 2004 | 10:30 AM
RyanEJ8's Avatar
Default Re: valve spring specs (rtype11)
Are you sure that boost causes valve float? I'm pretty sure that it doesn't.
Old Nov 29, 2004 | 01:05 PM
rtype11's Avatar
Default Re: valve spring specs (RyanCivic2000)
no boost doesnt cause float, you need to up your spring rates anyway.
Old Nov 29, 2004 | 01:35 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">did this years ago , forget but think it was around: seated pressure might be around 130lbs, open might be around 150lbs at proper installed height, thumb rule is add 1 lb pressure to the spring per psi of boost you plan on running to compensate for float.</TD></TR></TABLE>
no way its that high, even the stiffest aftermarket honda stuff you can buy is 95-100lbs at the seat, and most is in the 75-85 range.
Old Nov 29, 2004 | 05:16 PM
rtype11's Avatar
Default Re: valve spring specs (Jared)
yeah , ls1 specs, but Im at 110lbs closed
Old Nov 29, 2004 | 05:36 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">yeah , ls1 specs, but Im at 110lbs closed </TD></TR></TABLE>
what brand?
2point2
Mar 26, 2011 10:38 AM
Synapse
Nov 6, 2006 08:16 PM
aj99si
Jan 1, 2005 07:23 AM
ShortBusTechnologies
Oct 27, 2004 02:57 PM
JunIntegra
Apr 22, 2003 04:30 PM
