Pictures of my broken tranny
Old 11-26-2004, 01:31 PM
Maxime's Avatar
Default Pictures of my broken tranny
Well I broke the transmission on my Turbocharged Civic Si about 4 weeks ago.
At first I thought it was the differential. But after taking the transmission apart. My mechanic found out the diff. and the final drive were broken. I'm not sure which one broke first.
I bought an OBX LSD and found a used 4.26 LS final drive to replace the stock 4.40 one. I replaced all the bearings with new ones. I did not upgrade the clutch because it was still in great condition.
All in all it costed over 1000$ CAD to repair the damages.
Final Drive
Stock differential
Modified by Maxime at 5:46 PM 11/26/2004
Modified by Maxime at 6:08 PM 11/26/2004
Old 11-26-2004, 01:32 PM
tgreaves's Avatar
Default Re: Pictures of my broken tranny (Maxime)
pics not working...
Old 11-26-2004, 01:33 PM
manekDC2.'s Avatar
Default Re: Pictures of my broken tranny (tgreaves W)
CAN'T SEE ****!!!
Old 11-26-2004, 01:34 PM
Maxime's Avatar
Default Re: Pictures of my broken tranny (manikgsr)
Dammit!
I'll try to fix it. Give me a few minutes.
*Boostwerks*'s Avatar
So...what caused it to fail?
It doesn't seem like your making enough power to kill it.
Old 11-26-2004, 01:42 PM
Maxime's Avatar
Default Re: (Bryson)
I have no idea. It started making strange noises after an acceleration on wet pavement. (Aka: no traction al all). It blew after a 1-2 shift.
Old 11-26-2004, 02:13 PM
JDMs1eeper's Avatar
The name thing happend to me in my GSR tranny!! (boosted B20 in a civic hatch)
Except my final drive was completly clean of teeth and the diff outter ring was missing several teeth. I'll post pics. Funny! because it happend to me 2-3 weeks ago. We both had bad luck the same way and around the same time. CRAZY
I'll post pics later
Mine started making noises after a hard night of raceing w/ friend haha. But it died on me by just doing a 3rd gear pull...
Old 11-26-2004, 02:19 PM
Maxime's Avatar
Default Re: Pictures of my broken tranny (JDM S1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM S1eeper &raquo;</TD></TR><TR><TD CLASS="quote">The name thing happend to me in my GSR tranny!! (boosted B20 in a civic hatch)
Mine started making noises after a hard night of raceing w/ friend haha. But it died on me by just doing a 3rd gear pull...</TD></TR></TABLE>
I guess the difference is I was not going as fast when mine broke. I was going ~30mph. While I am sure you were going well over 60mph.
Old 11-26-2004, 02:59 PM
mattssi's Avatar
When i blew up my diff on my b16 tranny, it still would drive, just the rpms would climb, but the car would slow down then lurch forward. And it looked alot worse than that, the only difference it that my final drive was mint. And the ring gear was good too, must have been lucky i guess.
Old 11-26-2004, 03:03 PM
SOHC_MShue's Avatar
post your pics brad
Old 11-26-2004, 03:54 PM
USDM 4G VTEC's Avatar
bad countershaft bearing my guess
too much play caused a bad gear clearance and bam
sorry about that
topshotta
Transmission & Drivetrain
04-24-2012 08:36 PM
MadnessRacing
05-02-2008 08:23 PM
cartune network
10-30-2007 09:52 PM
MikesArmy
05-23-2006 10:36 PM
gubo22
10-30-2001 03:34 AM
Quick Reply: Pictures of my broken tranny
