turbo sizing.
Old Nov 29, 2004 | 10:23 PM
chihuahuamanx's Avatar
Default turbo sizing.
i got a good deal on a t4, and need QUICK feedback on what you guys think of this for an app running a good 12 pounds of boost on the street, more on track.
its a factory rebuilt garrett heres what he has to say.
Compressor A/R .60
Exhaust A/R .84
Has Garrett Factory Rebuilt Turbocharger plate on it. Has not been used since rebuild, so basically a brand new turbo charger. Comes with gaskets for mani to turbo, and both oil in and out.
thanks!
Old Nov 30, 2004 | 11:24 AM
Default Re: turbo sizing. (chihuahuamanx)
bawmp
Old Nov 30, 2004 | 12:21 PM
boosted92's Avatar
It's a T4 turbo, and likely way too big for your setup.
Old Nov 30, 2004 | 12:24 PM
*Boostwerks*'s Avatar
Agreed.
a .8*ar T4 would suck *** on anything but a big bore high reving H22.
Old Nov 30, 2004 | 12:44 PM
Default Re: (Bryson)
**** i forgot to mention. this is on an h22/h23. sorry fellas.
I talked w my shop and they said they ran a t4 on a b20 with virtually no lag. i dunno, seems too easy.....
Old Nov 30, 2004 | 12:49 PM
huh...virtually no lag?
riiight...so I guess they "virtually" had no turbo.
If its built with high compression and big bore, you can get away with it. In the end, It'll be up to you.
Old Nov 30, 2004 | 08:09 PM
JDMs1eeper's Avatar
I ran a big turbo setup like this on my b20. compressor 70a/r turbine 84a/r (vband) 64.5 trim. from a idle stop, full boost at 4k. From a roll almost instant full spool.
****, if you got an good deal on it... TRY IT. Inlinepro makes a new manifold now that has BOTH t3 and t4 flanges. Try it out tell us how you like it. THen switch to a T3 if you didnt like it and keep the same manifold. Good luck.
People used to say mine would never spool either, it did and i loved it. Just try it, you only live life once so you are the captin of your own ship.
(12.7 @ 110 , 2.0 60fttime, 8psi)
acrocat
May 27, 2008 01:11 PM
ProjectBB6
Sep 12, 2007 12:55 PM
Nytmair
Sep 14, 2004 10:49 AM
B20-T
Feb 12, 2003 11:26 AM
#417R
Dec 11, 2002 11:15 PM
