Oil Pan Tap
Old Nov 28, 2004 | 03:53 PM
civiceg500's Avatar
Default Oil Pan Tap
Hey peeps, This will be my first turbo install and i was wondering how much an oil tap weld job would be or is it something i can do myself? I'm buying an oil return fitting as part of a kit from Fast-Turbo.com. Any suggestions?
Old Nov 28, 2004 | 03:57 PM
AspectIndustries's Avatar
Default Re: Oil Pan Tap (civiceg500)
the thing is. Can you weld? If you can, then its easy, if you cant, then let someone do it for you. Dont cheap out on a mistake that can cost you your motor.
Old Nov 28, 2004 | 04:06 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Oil Pan Tap (synik)
oxyacetlene and a coat hanger, lol. where is abaz.
Old Nov 28, 2004 | 04:13 PM
dabig1's Avatar
Default Re: Oil Pan Tap (wantboost)
JB weld
(i'm joking)
Old Nov 28, 2004 | 04:17 PM
Frozen E's Avatar
H-T White Ops
Pay somebody if you don't have a welding rig. Should cost you any more than $25 or so if you take the predrilled pan and fitting fown to the shop. 15 minutes and you're on your way back home.
Old Nov 28, 2004 | 04:34 PM
adseguy's Avatar
Default Re: (IslandSi)
I took my oil oan and all the intercooler piping I cut to a garage and they did all of it for $35. You mark the hole and give them your oil pan and any garage will do it for like $5 since that's all the time it takes
ccjustin
Apr 27, 2006 02:53 AM
Ls-Turbo
Nov 19, 2005 07:51 PM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
TheYellowDart
Dec 17, 2004 07:51 PM
blackeg
Jun 6, 2004 07:55 AM
