B16A2 using Hondata Socketed P72?
Old Nov 25, 2004 | 10:20 AM
VinceVTEC's Avatar
Default B16A2 using Hondata Socketed P72?
Well, after purchasing an S100 w/ boost option & a socketed p72 ECU, a fellow HT member informed me that there are weird/mysterious problems that occur when P72s are used w/ B16s for some odd reason. I was not aware of this till after i purchased the P72...
Can anyone verify this? I performed a search in google, but came to no such conclusion.. and the HT search feature is down at this time.
Heres my setup:
'99 B16A2 EM1 - Stock Block
Boomslang OBD2B-OBD1 Conversion Harness
Socketed OBD1 P72 GSR ECU
Hondata S100 w/ Boost Option
Walbro 255lph Fuel Pump
RC 550cc Injectors Saturated
OEM MAP Sensor
And yes, i searched the Hondata board w/ no answers. Even though the Hondata site states that the P72 ECU is an acceptable ECU for my application. And also, i thought the hondata will read off the ROM chip program anyways... so, i was suprised to hear this at the least. I thought the only difference between the P72 and P28 was the IAB, and the knock sensor.
If anyone can please enlighten me on this situation? Anyone w/ experience please?
TIA!!!
Old Nov 25, 2004 | 10:54 AM
93turbo16's Avatar
P72 should work just fine.
Old Nov 25, 2004 | 11:08 AM
Full-Race Henry's Avatar
Default Re: B16A2 using Hondata Socketed P72? (VinceVTEC)
You will be fine.
Old Nov 25, 2004 | 11:19 AM
VinceVTEC's Avatar
Default Re: B16A2 using Hondata Socketed P72? (Full-Race Henry)
Phew!!! THANKS! i was kinda worried there after I heard, especially after just purchasing it.. thanks for the reassurance guys
Old Nov 25, 2004 | 12:40 PM
VinceVTEC's Avatar
btw, has anyone even heard of rumours like this? It was out of the blue for me.
Old Nov 25, 2004 | 06:45 PM
VinceVTEC's Avatar
Anyone have any information?
Old Dec 6, 2004 | 06:18 AM
JDMflavor_EJ's Avatar
I've heard of p72's weird problems on the b16 /w out Hondata. I don't know if it was chipped or what not but P72s don't work well with the B16 in cases I've seen.
Hondata, should be fine; I donno, never had hands on expierence.
naahnaah
Dec 18, 2008 11:56 PM
genius
Nov 27, 2003 10:38 AM
Nextelbuddy
Jul 24, 2003 10:43 AM
