Can i run a t4?????
Old Nov 29, 2004 | 07:43 PM
pubestripe's Avatar
Default Can i run a t4?????
hey whats up all. i have a sleeved 84mm b16 block with fully built ported and polished head and full upgrades to the head, ferrea springs, skunk turbo cams, etc. i have not completely finished my setup but i wanted to know if i could run a t4 with this setup. i am going to be running EMS and 2.5 inch ic piping along with full 3 inch exhaust and full race mani. is this possible to run a t4? i currently have a t3/t4b, so i want bigger and more power. i plan to get it tuned at 20psi... thanks!!!
Old Nov 29, 2004 | 08:38 PM
PrettyLude's Avatar
yes you can
Old Nov 29, 2004 | 08:46 PM
lanojp1's Avatar
Default Re: (PrettyLude)
you should have enough displacement to spool it up...idk how quickly you will hit full boost tho...
Old Nov 29, 2004 | 08:53 PM
pubestripe's Avatar
Default Re: (lanojp1)
well, that is what i was thinking. i am hoping that i can bump up the redline to 9 grand, but would it be worth it to just keep my .63 trim t3/t4??? i am confused... i know the t4 has more overall potential with hp's... but if i can hit full boost at lets say, 4 grand with the t3/t4, i dont know if it would be worth it to just keep it....
Old Nov 30, 2004 | 09:33 AM
pubestripe's Avatar
Default Re: (pubestripe)
anyone else got any other thoughts on this????
Old Nov 30, 2004 | 09:44 AM
PM-Performance's Avatar
if you only plan to tune to 20psi, its not worth it IMO. It all depends on how much power you wanna make? Alot of the t3/t4 turbos can go BIGGGGG hp these days
Old Nov 30, 2004 | 11:16 AM
SpoolnG2's Avatar
Default Re: (itr206)
hes right, theres really no need to go t4 now a days. These t3/t4 turbos are making 600+ whp. If i were you i'd go with a SC61 or a t3/t67. This way you'll be making the power you want but also have the better spool b/c of the t3 hotside compared to the t4.
Old Nov 30, 2004 | 01:46 PM
Lucky_Smurf's Avatar
Default Re: (SpoolnG2)
Of course you can run a t4 but really that's not that specific. Are you talking a t04s a t04r? What size compressor a t-76 or a t-61? The better question is to post up when you want spool by and what max power you want to make then you can get some recomendations about what turbo to run. Like someone mentioned before people are making 600whp+ with t3/t4s.
Old Nov 30, 2004 | 07:01 PM
pubestripe's Avatar
Default Re: (Lucky_Smurf)
i was lookign at a a t04r... specifically this one http://store.yahoo.com/cheapturbo/garrettto4r.html, but i made up my mind that i am going with a t3/t4e... i would enjoy full boost around 3500 if that is possible... so i think a t4 is outta the ? for now... isnt making too much sense to me now after researching it a little more...o and i am hoping 380whp at least...
turbodailydan
Nov 29, 2009 09:52 AM
Cole89ef
Aug 6, 2009 07:03 AM
pjhatchin
Oct 23, 2005 07:08 PM
The Tea-father
Apr 5, 2005 01:38 AM
Agamemnon
Jun 18, 2002 10:50 PM
