Ever seen a TT set up like this before?
Old Nov 26, 2004 | 01:34 PM
sporkcrx's Avatar
Default Ever seen a TT set up like this before?
Saw this in a jegs catalog, thought it was pretty crazy. One turbo feeds the other, haha.
Old Nov 26, 2004 | 01:36 PM
*Boostwerks*'s Avatar
I dunno.
That just seems horribly inefficent to me.
Old Nov 26, 2004 | 01:39 PM
JalopySiR's Avatar
Default Re: (Bryson)
I believe some diesels do it because of the smaller a/r response and the multiplication effect of boosting already pressurized air. This leads to extremely high pressure levels from a low RPM. Remember Diesels have low redlines. This would give a diesel a nice big powerband from relatively small displacement.
For a gas powered dragster I don't think it is neccessary, but...
Old Nov 26, 2004 | 01:40 PM
wantboost's Avatar
Who is Mr Robot?
that is a staged turbo system, one turbo for lower boost the other for hi. used to make insane pressure ratios on things such as over-the-road trucks.
Boostage's Avatar
one turbo spools the other by blowing boost into the exhaust turbine..
Old Nov 26, 2004 | 01:48 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Boostage)
no, you are looking at it wrong. it goes, exhaust-1st turbine-2nd turbine-downpipe. on the cool side it goes filter-1st compressor-2nd compressor-intake manifold.
Old Nov 26, 2004 | 01:51 PM
mrbsponge's Avatar
i believe it is called "compund turbo charging" i believe there was a supra model that had this on it.
also i think this is an upgrade for diesels as well, it helps spoll the bigger turbo
Old Nov 26, 2004 | 02:12 PM
.Ash's Avatar
that looks like a cummins motor? wantboost; the last quote in your sig is mine hahahaha.
Old Nov 26, 2004 | 02:23 PM
HXMan's Avatar
Default Re: Ever seen a TT set up like this before? (sporkcrx)
I like that.
Old Nov 26, 2004 | 02:25 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Ever seen a TT set up like this before? (HXMan)
lets just hope that obx doesnt get any ideas from this post. lol
Old Nov 26, 2004 | 02:44 PM
sporkcrx's Avatar
Default Re: Ever seen a TT set up like this before? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">lets just hope that obx doesnt get any ideas from this post. lol</TD></TR></TABLE>
lol. Yea it was in the diesel truck section.
Old Nov 26, 2004 | 03:57 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Saw this in a jegs catalog, thought it was pretty crazy. One turbo feeds the other, haha.
is it me or the doewpipe on the first turbo looks like PCV pipe?
and also whats up with the hose clamp on the downpipe????
thats not a V band
looks more like a photoshop to me
i would like the link to the jegs manual
Old Nov 26, 2004 | 04:16 PM
sporkcrx's Avatar
Default Re: Ever seen a TT set up like this before? (USDM 4G VTEC)
Here you are, go crazy.
http://www.jegs.com/cgi-bin/nc...r=361
Old Nov 26, 2004 | 05:15 PM
Bloodline's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">i believe it is called "compund turbo charging" </TD></TR></TABLE>
Bingo! A WinnAr is yuO. Or the short version is "compounding". Its how those large alcohol tractor pullers get up in the 140 psi range running 3 turbos. If you ever get the chance, get a close up look at one of those things. Its awesome.
jeff
Old Nov 26, 2004 | 07:31 PM
Tad's Avatar
Tad
looks cool to me, but i'd think it'd work better with them both running off the same exhaust? maybe?
Old Nov 26, 2004 | 08:04 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Tad)
no, this setup is designed to make crazily stupid boost levels that arent attainable with one turbo. that setup can easily run 80psi reliably if needed.
Old Nov 26, 2004 | 08:40 PM
mrbsponge's Avatar
thats why its on the diesel section, my stock duramax is sitting at about 30psi right now..............and the turbo is HUGE........
Old Nov 26, 2004 | 10:14 PM
liam821's Avatar
25 Year Member
Default Re: (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">they had a dragster at SEMA with a setup like this but the turbos were huge if i can find a pic i took ill show ya. they wated to be the first desel to go 200 in the quarter</TD></TR></TABLE>
I was just thinking of that guy. I talked to him for 10mins. Badass dragster. You do a turbo setup like that so you can run like 80+psi of boost.
liam
Old Nov 27, 2004 | 04:45 AM
turboex's Avatar
our nuke tractors use the same setup at work. Makes some crazy torque. There peterbuilts.
Old Nov 27, 2004 | 06:20 AM
turbod16y7vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
thats not a V band
i would like the link to the jegs manual</TD></TR></TABLE>
dude hose clamps can hold some stuff i don't know what your talking about
Old Nov 27, 2004 | 10:36 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Ever seen a TT set up like this before? (jerseykid609)
mmm tasty, think that tb can be fabbed to fit a b16? lol
Old Nov 27, 2004 | 11:25 AM
J337_UNIT's Avatar
can someone explain to me how this differs from sequential turbocharging? id just like to know the difference.
Old Nov 27, 2004 | 11:46 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Ever seen a TT set up like this before? (J337_UNIT)
with this setup boost is fed into a turbo where it is further pressurized. in a sequential setup boost is fed from both turbos into the same charge pipe.
Old Nov 27, 2004 | 03:43 PM
EJ8Joel's Avatar
I saw this setup at SEMA in a truck, i think it said it was the quickest diesel in the world. I spent a lot of time looking at it, didnt understand it, but then realized it was a diesel. Pretty cool stuff.
hoorah
Aug 1, 2013 05:06 PM
Revlon Charly
Mar 14, 2007 09:37 PM
cxhb
Feb 18, 2006 08:20 PM
joek84
Feb 17, 2005 08:33 PM
1.8T_EG
Jul 21, 2003 05:01 PM
