Reading oil dipstick
Old Nov 27, 2004 | 12:15 PM
XxRoCkMaNxNEOxX's Avatar
Default Reading oil dipstick
i went to check my oil today since its leaking oil to a very minimal point. when i park i only see 3 little drops nothing major but drives me crazy. anyway when i check my oil it was low(first dot) started to fill it up but i ran out of oil. the reading now was 1/4 under the second dot. i went driving on the highway and street (40-50mi). got home and checked my oil to make sure everything was ok i check it and now its 1/4 above the second dot. looks like i have too much oil. anyone know which is the right reading?
Old Nov 27, 2004 | 12:16 PM
sporkcrx's Avatar
Default Re: Reading oil dipstick (XxRoCkMaNxNEOxX)
Did you check the oil the first time when the engine was at operating temp?
Old Nov 27, 2004 | 12:19 PM
Default Re: Reading oil dipstick (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Did you check the oil the first time when the engine was at operating temp?</TD></TR></TABLE> yeah when its at reg. temp it reads higher. im using Mobil1 10w30
Old Nov 27, 2004 | 12:21 PM
SOHC_MShue's Avatar
yea i believe the oil level raises a little after driving the car around. I've done this before too...accidentally put too much in.
Old Nov 27, 2004 | 12:23 PM
Default Re: Reading oil dipstick (SOHC_MShue)
so which reading is correct. the reading when the car is cold or at operating temp? just wondering so i dont put too much oil
Old Nov 27, 2004 | 12:25 PM
raene's Avatar
When the engine's warm, shut the car off and wait 5-10 mins. Then take the reading. That's the most consistent way.
Old Nov 27, 2004 | 12:28 PM
Default Re: Reading oil dipstick (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">When the engine's warm, shut the car off and wait 5-10 mins. Then take the reading. That's the most consistent way.</TD></TR></TABLE>
sounds good
Old Nov 27, 2004 | 01:14 PM
SOHC_MShue's Avatar
do you guys think its bad to have as much as he said with about a 1/4 over the second dot. I've done this twice now by accident
Old Nov 27, 2004 | 09:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">do you guys think its bad to have as much as he said with about a 1/4 over the second dot. I've done this twice now by accident </TD></TR></TABLE>
i would also like to know. bump
Old Nov 27, 2004 | 09:57 PM
enigma94's Avatar
Its probably not going to hurt anything, but they did put that second dot there for a reason
The best way to do it is to park your car on a even surface let it sit (1-2) hours then read the stick, make sure its in between the dots. This insures that there is no leftover oil still in the upper part of the block and head( like if you only let it sit for 10-15min) If you make sure its in the middle the oil will then rise (on the stick) to the top line when at opperating temp.
Old Nov 27, 2004 | 10:03 PM
stinker504's Avatar
Do not put too much oil in. I had a problem with the oil not leaving the turbo do to the fact the return was not under the oil level.
Old Nov 28, 2004 | 09:17 AM
Default Re: (stinker504)
so check it about an hr after a drive
motormike40
Sep 18, 2006 07:23 PM
Burgh
Sep 26, 2005 12:30 PM
X2BOARD
Jan 13, 2004 03:30 PM
IloveNewt
Jan 11, 2004 02:10 PM
PY2KITR1060
May 4, 2002 01:30 PM
