base fuel pressure
Old Nov 24, 2004 | 07:05 AM
maxspeedhonda's Avatar
Default base fuel pressure
I was just wondering what my base fuel pressure should be a near idle. I am reading 40psi now. It is a 84mm b16a w/880cc injectors (aem rail). Should be pressure be higher or lower?
Old Nov 24, 2004 | 09:33 AM
Default Re: base fuel pressure (maxspeedhonda)
bump
Old Nov 24, 2004 | 10:16 AM
PM-Performance's Avatar
it can be whatever you want it to be at. Depends on too many things. Usually people will adjust the pressure up if the duty cycles get too high. If you have no reason to change it then leave it the way it is.
Old Nov 24, 2004 | 01:49 PM
Default Re: base fuel pressure (itr206)
This is a fresh build and the car idles very poorly and I was wondering if maybe the FP could be attributing to it. What is everyone elses base fuel pressue average?
Old Nov 24, 2004 | 01:54 PM
93turbo16's Avatar
on my z6, I have it at 50 with the line off the reg.
Old Nov 24, 2004 | 01:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxspeedhonda &raquo;</TD></TR><TR><TD CLASS="quote">This is a fresh build and the car idles very poorly and I was wondering if maybe the FP could be attributing to it. What is everyone elses base fuel pressue average?</TD></TR></TABLE>
The tune prob has to do with it. You are supposed to make sure the fuel and timing maps are on if you want it to idle correctly. What fuel management are using?
Old Nov 24, 2004 | 02:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">
The tune prob has to do with it. You are supposed to make sure the fuel and timing maps are on if you want it to idle correctly. What fuel management are using?</TD></TR></TABLE>
Hondata s200. Like I said, this is a fresh build and has not been tuned yet, the hondata is just running a rough basemap until my dyno appointment. The rail and reg came off my old turbo stock b16a and the fuel pressure is still set for whatever the tune was for.
Old Nov 24, 2004 | 03:19 PM
Alchemist's Avatar
Im not absolutely certain, but I think stock fuel pressure on Bseries is like 42psi.
Old Nov 24, 2004 | 03:20 PM
you answered your own question then , if its not tuned, then thats why itsa a lumpy idle. When its tuned and figured out it prob wont do that. have patience and let the tuner do his thing
aeenox
36
Feb 14, 2008 02:19 PM
h22 ac
Aug 13, 2006 01:48 PM
Something Funny
Jul 12, 2006 07:58 PM
c17r15
Sep 4, 2004 06:45 AM
tz-devil77
Jan 9, 2004 10:27 PM
