Back from the Dyno, New #'s
Old Nov 24, 2004 | 04:45 PM
jmal1919's Avatar
Default Back from the Dyno, New #'s w/ question
Went down to the dyno today to see what my timing was like under 6psi & the AFC. Well, with some slight tweeks to the AFC, better gas in the tank, cooler temps, the ol f23 managed to get some pretty good numbers
Several runs were done, but the dyno above was from June and today, with today's #'s being higher. The timing as observed was about 25degrees, which I know isn't ideal, but with the f23, we all know you can't adjust the timing. What was noticed, is that the timing was automatically adjusted by the ECU, since I belive stock, timing is about 28 degrees for the f23 NA. At 10psi, timing was observed to be drastically retarded, but can't remember the exact amount.
I guess to keep this technical, does anyone know why the timing was drastically re-tarded at 10psi with the f23?
After talking to several folks at the shop, I may hold off on my plans to get the EMS, since I'm making close to what my goal was (250whp & wtq), and the setup is fairly safe as is.
Modified by jmal1919 at 9:25 PM 11/24/2004
Old Nov 26, 2004 | 07:06 AM
jmal1919's Avatar
Default Re: Back from the Dyno, New #'s w/ question (jmal1919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmal1919 &raquo;</TD></TR><TR><TD CLASS="quote">
I guess to keep this technical, does anyone know why the timing was drastically re-tarded at 10psi with the f23, can't remember how much exactly, but I think it was something like less than 20 degrees?
Old Jun 1, 2005 | 12:36 PM
wontonjohnny's Avatar
do you think the afc is better than those data things?
also does the f23 have a knock sensor?
thanks
Old Jun 1, 2005 | 12:39 PM
ITSME4G63's Avatar
what turbo are you using? is it a dsm turbo setup you have?
Mike Lowwryyy
Engine Management and Tuning
Jul 12, 2012 08:50 AM
nasteawhun
Jul 7, 2008 10:09 AM
hmongboyLS
May 13, 2004 11:36 PM
brownman72000
Jun 8, 2002 07:33 AM
