Check valve issues
Old Nov 24, 2004 | 07:00 PM
illusive's Avatar
Default Check valve issues
Ok so I did a little research on check valves since I have to wait for my missing link for 2+ weeks since its on back order I needed something to run my car with until then. So I found some threads about them I made mine look like this
It seems to work ok I used 4 check valves which alot of ppl say they use any where from 1-3 normally. But still under WOT it will still detects boost like its not releasing enough pressure from them. I got the black tetra ones from the pet store. Any ideas? the check valves are way better then no check valves but I thought these were suppose to fix my problem competely specially since I am using 4
Old Nov 25, 2004 | 03:45 AM
crispydee's Avatar
Default Re: Check valve issues (illusive)
I've seen a set up with 6 of them in, try adding another. there is a lot of air to release for it not to see any boost.
Old Nov 25, 2004 | 04:32 AM
integlspwr2k's Avatar
That is the correct way to run check vavles.
I seen people just run them like..
TTTTT
Which is most certainly wrong.
Boostless97Lude
Feb 19, 2003 12:33 PM
uneekcrx
Sep 2, 2002 04:20 PM
filetofit
Jun 4, 2002 02:56 PM
Giuseppe
Feb 4, 2002 05:31 PM
