help with burning with moates burner
Old Nov 26, 2004 | 07:51 PM
alexsracing's Avatar
Default help with burning with moates burner
I have the burn1 from moates and this step has me confused (5 To burn a portion of the buffer to the chip, input the addresses of the buffer you'd like to have burned to the chip. Also, input the address within the chip that you'd like that portion of the buffer to be programmed to. For more information, see "Advanced Addressing". Note - All addresses and filesizes must be 64 byte aligned) Does it matter or need an address to put the file from buffer mem on to the chip. Does it matter what address we use for the ecu to see it?
Old Nov 27, 2004 | 12:12 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: help with burning with moates burner (alexsracing)
Those directions sound confusing.
Just click on the chip you have in the pull down menu. Make sure you have a blank chip (hit test or just erase it to be sure). Once that is done load a file into the buffer and then click program chip. That's it.
Old Nov 27, 2004 | 11:31 AM
adseguy's Avatar
Default Re: help with burning with moates burner (ActiveAero)
yeah it's real easy to use. don't even mess with those address values they work out themselves. Just click load file to buffer and choose your .bin file. Then click program and it should take baout 5 seconds to program it. That's it your done.
Old Nov 27, 2004 | 11:37 AM
SOHC_MShue's Avatar
Default Re: help with burning with moates burner (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">yeah it's real easy to use. don't even mess with those address values they work out themselves. Just click load file to buffer and choose your .bin file. Then click program and it should take baout 5 seconds to program it. That's it your done.</TD></TR></TABLE>
thats all it takes
B18C1CYA
Engine Management and Tuning
Dec 4, 2021 03:18 PM
Honda4life777
Jul 11, 2009 09:39 PM
jedsus
Apr 25, 2008 08:36 PM
the.hamburglar
Mar 20, 2006 03:28 PM
