Question about nirtous kit
Old Nov 28, 2004 | 08:23 AM
StockBlockRob's Avatar
Default Question about nitrous kit
Probably switching to nitrous, just wondering if anyone has used this kit and how do you like it. Was it easy to install? Looks like a great design to me.
Thanks in advance
http://www.nitrousexpress.com/Pages/20200.htm
Old Nov 28, 2004 | 08:32 AM
Stewie's Avatar
Default Re: Question about nitrous kit (vtecrob16a)
sounds cool but I don't see how it works
Old Nov 28, 2004 | 08:47 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Question about nitrous kit (Stewie)
its a spacer that installs between the injector and the block, it sprays nitrous and fuel through passages machined into the bottom of the same spacer. the solenoids are self contained in the fuel rail provided
Old Nov 28, 2004 | 09:49 AM
Stewie's Avatar
Default Re: Question about nitrous kit (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">its a spacer that installs between the injector and the block, it sprays nitrous and fuel through passages machined into the bottom of the same spacer. the solenoids are self contained in the fuel rail provided</TD></TR></TABLE>
oh, so is this just like the nozzle system from nos? Because if it is, I wouldn't use it.
Old Nov 28, 2004 | 09:52 AM
wantboost's Avatar
Who is Mr Robot?
yep, same thing
Old Nov 28, 2004 | 09:57 AM
MooreBoost's Avatar
I like Zex, that's what I would use if I ever got a system. However the direct port kit would be nice if you are planning on spraying alot, what kind of power do you want out of it?
Old Nov 28, 2004 | 07:01 PM
Default Re: Question about nitrous kit (tegunderpressure)
not really sure, looking to have a 12 second car for the upcoming season
Old Nov 28, 2004 | 07:05 PM
MooreBoost's Avatar
I would probably go for a direct port then. That kit doesnt look bad but when I read a review of a similar kit in SCC it sounded rather unfinished. You really can't go wrong with a standard NOS direct port kit with exterior plumbing and what not.
Old Nov 29, 2004 | 08:26 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">I like Zex, that's what I would use if I ever got a system. However the direct port kit would be nice if you are planning on spraying alot, what kind of power do you want out of it?</TD></TR></TABLE>
I give the ZEX kit .
Old Nov 29, 2004 | 10:59 AM
Default Re: Question about nitrous kit (RyanCivic2000)
hmm,I really wanted to hear about this kit not what your preference was...this website is pretty worthless...
Old Nov 30, 2004 | 05:37 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecrob16a &raquo;</TD></TR><TR><TD CLASS="quote">hmm,I really wanted to hear about this kit not what your preference was...this website is pretty worthless...</TD></TR></TABLE>
Well than go spend $1146 ******* dollars on a nitrous kit when the ZEX kit will do just as good for under $500.....and find another website.
Old Nov 30, 2004 | 05:44 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Well than go spend $1146 ******* dollars on a nitrous kit when the ZEX kit will do just as good for under $500.....and find another website.</TD></TR></TABLE>
Wurd.
Old Nov 30, 2004 | 06:06 PM
Stewie's Avatar
I know everyone has their different preference, but I personally, would never use a dry shot. In my opinion, it's no coincidence that many people blew their motors on wet/dry setups.
It's a proven fact that dry shots distribute nitrous unevenly to the cylinders causing different fuel mixtures between the cylinders. This is the reason why many people get inconsistent plug readings.
Old Nov 30, 2004 | 07:15 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stewie &raquo;</TD></TR><TR><TD CLASS="quote">
It's a proven fact that dry shots distribute nitrous unevenly to the cylinders causing different fuel mixtures between the cylinders. This is the reason why many people get inconsistent plug readings.</TD></TR></TABLE>
No it's not a proven fact, unless you're placing your nozzle closer than 12" from the throttle body. I like to keep mine at 18" or farther.
Old Nov 30, 2004 | 11:41 PM
Stewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">No it's not a proven fact, unless you're placing your nozzle closer than 12" from the throttle body. I like to keep mine at 18" or farther.</TD></TR></TABLE>
yes it is. Put "dry shot uneven distribution" in any search engine and see what you get.
Also, if dry shots weren't known for this, what's your explination of being limited to a 75 shot for dry setups
Old Dec 1, 2004 | 12:03 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
since when were dry shots limited to 75?
Old Dec 1, 2004 | 05:55 AM
Stewie's Avatar
Default Re: Question about nitrous kit (bruceleeroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">since when were dry shots limited to 75?</TD></TR></TABLE>
From what I know, the majority of the systems for imports are. I know for a fact this is true for nos and zex. I also believe it is for nx too.
Old Dec 1, 2004 | 06:28 AM
PM-Performance's Avatar
On NOS kits, over 60 dry more than none you will run pretty damn lean. I dont like dry kits what so ever.
ANd yes he is right about uneven dist with dry kits and single fogger kits.
And yes that is a very good kit. Hard lines are a big pain in the ***. I would go soft lines any day of the week
Old Dec 1, 2004 | 08:31 AM
RyanEJ8's Avatar
Also, if dry shots weren't known for this, what's your explination of being limited to a 75 shot for dry setups</TD></TR></TABLE>
So in other words your a tool who believes everything you read on Honda-Tech.
From what I know, the majority of the systems for imports are. I know for a fact this is true for nos and zex. I also believe it is for nx too.</TD></TR></TABLE>
That's funny because I've ran 100 shot dry with my ZEX kit and Matt Patrick has run up to a 200 shot dry with a modified ZEX dry kit.
Old Dec 1, 2004 | 08:37 AM
What size pills did you use for a 100-200 on Zex?Ive hear dof it being done, but its not smart
Old Dec 1, 2004 | 08:52 AM
RyanEJ8's Avatar
Default Re: Question about nitrous kit (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">
What size pills did you use for a 100-200 on Zex?Ive hear dof it being done, but its not smart</TD></TR></TABLE>
I believe the 100 shot was a .043 pill and 125 shot is .052 pill. You'd have to ask Matt Patrick which one for a 200 shot. It's not dangerous unless you don't have the right injectors and fuel management.
Old Dec 1, 2004 | 09:03 AM
i just get really leary with that on dry shots. I wont touch anything but some sort of DP for higher shots. Even if its only nitrous in each cylinder. That way there is no room for dist probs. Or I thought of getting the nozzles that inject straight out from the tips, and run 2 of them into the back of the manifold. to get one nozzle per 2 cyls. That might get touchy though with the amount of space for spray patterns. Thats just me though.
Old Dec 1, 2004 | 09:20 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">i just get really leary with that on dry shots. I wont touch anything but some sort of DP for higher shots. Even if its only nitrous in each cylinder. That way there is no room for dist probs. Or I thought of getting the nozzles that inject straight out from the tips, and run 2 of them into the back of the manifold. to get one nozzle per 2 cyls. That might get touchy though with the amount of space for spray patterns. Thats just me though. </TD></TR></TABLE>
Placing the nozzle 18" or farther from the throttle body allows the nitrous to spread out and distribute evenly with the air in the intake manifold.
Old Dec 1, 2004 | 10:27 AM
in theory. That doesnt happen all of the time though. I know, Ive run tons of nitrous set ups. It becomes a prob on higher shots i have noticed
Old Dec 1, 2004 | 01:55 PM
SYD's Avatar
SYD
And yes that is a very good kit. Hard lines are a big pain in the ***. I would go soft lines any day of the week </TD></TR></TABLE>
u can go ALOT higher on a dry shot..u just have to have the fuel to back it u, which doesn't necessarily have to come from the kit itself...tuning in your management/injectors (just like in boost apps)to compensate, will easily make this possible..in the "bone stock motor honda world" limited to 60-75, yes i agree..
