plugging up oil feed line?
Old Nov 29, 2004 | 09:29 AM
scartail's Avatar
Default plugging up oil feed line?
my turbo is hosed. i'm burning oil. is it ok that i disconnect the oil feed line and cap it off? turbo is in turbo heaven now (junkard turbo)... any advice.. would be great...
Old Nov 29, 2004 | 09:53 AM
raene's Avatar
Default Re: plugging up oil feed line? (scartail)
I used a 1/8" plug and just capped the line, yes it's fine to do it that way Home Depot has 'em for like 30 cents.
Old Nov 29, 2004 | 10:00 AM
PM-Performance's Avatar
Default Re: plugging up oil feed line? (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">I used a 1/8" plug and just capped the line, yes it's fine to do it that way Home Depot has 'em for like 30 cents.</TD></TR></TABLE>
if you tapped off your block then you got the wrong plug. its not a standard pipe thread in the block
Old Nov 29, 2004 | 10:07 AM
raene's Avatar
Default Re: plugging up oil feed line? (itr206)
I know, and no, I didn't I plugged the hole in the distribution block I have. Sorry, I should've made that clear. Yes, the block is BSPT, *not* NPT.
Old Nov 29, 2004 | 10:15 AM
Old Nov 30, 2004 | 02:11 AM
scartail's Avatar
so the 1/8 npt fitting will fit the 1/8 femal compression/flare fitting?
Old Nov 30, 2004 | 07:31 AM
scartail's Avatar
Default Re: plugging up oil feed line? (slow poke)
i was thinking about change the oil distribution scheme. I have the t near the block now. thanks for the input guys. i'm just gong to take have a union and plug it up.
Boostedb20EH2
Mar 16, 2007 12:44 PM
DIYMIKE
Jan 24, 2006 05:14 PM
b18civicek850
Apr 11, 2004 10:00 AM
Boostage
Jan 15, 2004 06:23 AM
dohcvtec717
Apr 1, 2002 06:58 PM
