93 octane @20psi?
Old Nov 28, 2004 | 03:57 PM
dabig1's Avatar
Default 93 octane @20psi?
Is this possible with a very good tune?on a D?
Modified by dabig1 at 5:21 PM 11/28/2004
Old Nov 28, 2004 | 04:04 PM
Syner-G-Racing LLC's Avatar
Default Re: 93 octane @20psi? (dabig1)
I believe you can answer your own question.
Old Nov 28, 2004 | 04:05 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 93 octane @20psi? (Syner-G-Racing)
setup???
Old Nov 28, 2004 | 04:06 PM
2SLO's Avatar
it depends on what turbo you are using. 20 psi could be on a 14b or a sp67... very different
Old Nov 28, 2004 | 04:11 PM
dabig1's Avatar
Default Re: 93 octane @20psi? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">setup???</TD></TR></TABLE>
I am still debating on a setup...
d16 block
stock bore
vitara pistons
eagle's
Stock head vtec/non-vtec don't matter
BMC mani
16g(good for 20psi?)
Johny racecar intercooler
Uberdata
i dont know if 450's wouldbe enough
I'm steal searching around,i did not expect everybody to figure out everything for me...
alpha's Avatar
On a stock bottom end? No.
Old Nov 28, 2004 | 04:12 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 93 octane @20psi? (0x64)
um, 20psi on d sleeves, probably not.
Old Nov 28, 2004 | 04:14 PM
dabig1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">On a stock bottom end? No.</TD></TR></TABLE>
even if its posted?
Old Nov 28, 2004 | 04:15 PM
alpha's Avatar
Not necessarily true. My buddy here is pushing 21lbs with a T3/T04E (dont know the wheel trims) on pump gas with CP pistons, Eagle rods and stock sleeves. Granted he has a very good tune and doesnt push the RPM.
Old Nov 28, 2004 | 04:17 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabig1 &raquo;</TD></TR><TR><TD CLASS="quote">
even if its posted?</TD></TR></TABLE>
To be honest I am going to say no. I dont think a D series with a stock bottom end would last at 20lbs from your run of the mill T3/T04E or T3/T04B on pump gas.
Old Nov 28, 2004 | 04:19 PM
wantboost's Avatar
Who is Mr Robot?
dabig1 has been on hmt a few too many times, lol
dabig1's Avatar
To be honest I am going to say no. I dont think a D series with a stock bottom end would last at 20lbs from your run of the mill T3/T04E or T3/T04B on pump gas.</TD></TR></TABLE>
Did you read my other post?
d16 block
stock bore
vitara pistons
eagle's
BMC mani
Uberdata
Old Nov 28, 2004 | 04:21 PM
dabig1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">dabig1 has been on hmt a few too many times, lol</TD></TR></TABLE>
why do you say that?is that a bad thing?
wantboost's Avatar
Who is Mr Robot?
no, i just like my motor too much to trust myself to drill and tap a hole in it. hmt has some good ****
Old Nov 28, 2004 | 04:25 PM
dabig1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">no, i just like my motor too much to trust myself to drill and tap a hole in it. hmt has some good ****</TD></TR></TABLE>
lol,i like to do stuff by my self,i enjoy it more
Old Nov 28, 2004 | 04:29 PM
wantboost's Avatar
Who is Mr Robot?
i do a lot of things by myself, but i'm too poor to afford a new block if i **** it up.lol
Old Nov 28, 2004 | 04:30 PM
alpha's Avatar
I only read this post. I'm not familiar with the Suzuki Vitara pistons. What would your final compression ratio be at with Suzuki Vitara pistons. 20lbs with a 16G, good tuning and keeping the RPM conservative you should be fine.
Old Nov 28, 2004 | 04:46 PM
dabig1's Avatar
I only read this post. I'm not familiar with the Suzuki Vitara pistons. What would your final compression ratio be at with Suzuki Vitara pistons. 20lbs with a 16G, good tuning and keeping the RPM conservative you should be fine.</TD></TR></TABLE>
Vitara pistons are known to hold up to 22psi,they are mad of higher grade materials and have beefier ringlands.the eagles should hold fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">i do a lot of things by myself, but i'm too poor to afford a new block if i **** it up.lol</TD></TR></TABLE>
I destroyed my dads 2.9 ford ranger block by trying to take the pulley off when we took it apart to rebuilt it.The pulley was giving me a real hard time.
New Block:$180
New pulley:$60
Learning that you should use a puller to remove pulley:priceless
Old Nov 28, 2004 | 04:48 PM
wantboost's Avatar
Who is Mr Robot?
lol, i could probably find a new b16 bare block for a couple hundred bucks, but if i did then it would just lead to more money as i would get it sleeved
Old Nov 28, 2004 | 04:51 PM
D-tuned's Avatar
I've done 20psi on a stock LS on shell 93 octane. Mydyno sheet is on here somewhere. The car is still running stock. I tuned the car myself. check out my sig
Old Nov 28, 2004 | 04:54 PM
danl's Avatar
Banned
Its doable as long as the charge system is efficient at the flow and boost levels. Static compression is going to have to be around 8:1 however.
I wouldn't want to daily drive it at those boost levels. Your going to run into periodic detonation due to things out of your control. Their really isn't a good enough detonation management system on the market to take care of you in these instances.
Old Nov 28, 2004 | 05:02 PM
dabig1's Avatar
Default Re: 93 octane @20psi? (2000civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">I've done 20psi on a stock LS on shell 93 octane. Mydyno sheet is on here somewhere. The car is still running stock. I tuned the car myself. check out my sig</TD></TR></TABLE>
Holy **** is your engine on stockk internals?LS engines can handle 20psi?more info please!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danl &raquo;</TD></TR><TR><TD CLASS="quote">Its doable as long as the charge system is efficient at the flow and boost levels. Static compression is going to have to be around 8:1 however.
I wouldn't want to daily drive it at those boost levels. Your going to run into periodic detonation due to things out of your control. Their really isn't a good enough detonation management system on the market to take care of you in these instances.</TD></TR></TABLE>
Yeah,i was thinking maybe 16psi daily driven and 20psi at the track.
On a y7 the comp. is 8.5:1,but i think a little higher on z6.i still dont know what head i'm gonna use...
Old Nov 28, 2004 | 05:05 PM
dabig1's Avatar
Also,are you daily drivin 20psi?
SilverWarrior
Mar 31, 2008 11:39 PM
c5stunna
11
Oct 28, 2007 01:36 PM
totoy
13
Sep 13, 2006 05:44 PM
Tapen00n
Mar 30, 2005 08:08 PM
Arch-Angel
Jul 8, 2004 07:56 PM
