need basemap created. ill pay for it. >>
Old Nov 24, 2004 | 12:56 PM
platinum00's Avatar
Default need basemap created. ill pay for it. >>
i need a basemap created so i can break my motor in and drive to the dyno.
setup.
p28 ecu,
hondata s200 w/boost
3 bar map
750cc saturated.
t3/4 50 trim .48 a/r
sohc 75.5 mm bore 9.1 comp..
full 3 inch turboback
i think that's all you need. please let me know if you need more.
i would like vtec set at like 6k or above, and im not sure what the boost cut option is. but i dont really want to hit boost. i dont know if you can like set the boost cut to like 3psi or whatever.
i need a chip and a burn.
just let me know what you want. i got trades and or paypal
thanks
platinum.
Modified by platinum00 at 1:10 PM 11/25/2004
Old Nov 24, 2004 | 01:06 PM
Suprdave's Avatar
Default Re: need basemap created. ill pay for it. >> (platinum00)
pm sent.
Old Nov 24, 2004 | 02:43 PM
Tchleung's Avatar
Post on PGMFI.org forums. someone will make it for you for free. It's not that hard.
Old Nov 24, 2004 | 03:49 PM
Quad-Damag's Avatar
Default Re: (Tchleung)
i wouldn't drive crazy on a base map, say good bye to ur motor
Old Nov 24, 2004 | 04:20 PM
RZFD's Avatar
Tow it to your tuner. If he doen't have a base map to start it... find a new ******* tuner.
Old Nov 24, 2004 | 04:24 PM
SOHC_MShue's Avatar
Default Re: need basemap created. ill pay for it. >> (RZFD)
you will be fine driving to the tuner on a basemap. If you aren't hitting boost then you should be just fine.
Old Nov 25, 2004 | 06:30 AM
platinum00's Avatar
Default Re: need basemap created. ill pay for it. >> (SOHC_MShue)
yea im for sure not boosting.
i dont want to just tow it to the tuner. i want to make sure things are running right.
my luck i will get there and something will be way off.
platinum.
Old Nov 25, 2004 | 09:10 AM
platinum00's Avatar
oh yea, i have a 3bar map too. sorry
platinum.
vy3tnamezz
Sep 1, 2009 07:10 PM
D15Bbigred
May 8, 2007 01:48 PM
motormike40
Nov 23, 2006 04:15 PM
autoEXturbo
May 14, 2003 02:21 PM
95c1v1cs1
Apr 15, 2003 12:13 PM
