using a switch on J1 on a chipped ECU?
Old Nov 26, 2004 | 01:40 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default using a switch on J1 on a chipped ECU?
long story short, im going to be running uberdata soon, and my P28 is socketed for management... so, while tunning, im going to want to be able to run back and forth from uberdata back to stock.
now, when you jump J1, the external rom is active.. and if you break it, returns it back to stock.. so why not put a switch?
has anyone ever done this?
Old Nov 26, 2004 | 02:09 PM
Boosted Chemist's Avatar
Default Re: using a switch on J1 on a chipped ECU? (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">long story short, im going to be running uberdata soon, and my P28 is socketed for management... so, while tunning, im going to want to be able to run back and forth from uberdata back to stock.
yes you are correct, and ive seen a switch soldered in b4 but who needs the stock bin
Old Nov 26, 2004 | 02:36 PM
adseguy's Avatar
Default Re: using a switch on J1 on a chipped ECU? (Boosted Chemist)
Yeah i've seen a pic with someone installing a switch as well. Go ahead and do it, just make sure it's hard to accidently switch it. Otherwise I don't see how hard it is to burn a chip with the stock ROM.
Old Nov 26, 2004 | 04:29 PM
Built B16A's Avatar
Default Re: using a switch on J1 on a chipped ECU? (adseguy)
well.. your right.. but whats a stock BIN? im using 1.70 and the closest i can get, it going from a stock GSR, and importing the P28.. and going like that..
the thing is, my car is a VX.. and im coverting the ECU up to P28 along with the O2.. a few weeks ago, it wasn't at all on the P28, so ide like ot know for a fact the ECU is stock.. that way i can get it right on the P28.. then chip from there.
do you have a stock P28 bin?
Old Nov 26, 2004 | 04:48 PM
liquidxEG's Avatar
if you're running larger injectors, you're NOT going to want to go back to stock =X
Old Nov 26, 2004 | 08:52 PM
Built B16A's Avatar
Default Re: (liquidxEG)
****, i never thought about that... and yes, i'll be running DSM 450's...
Old Nov 26, 2004 | 10:35 PM
SOHC_MShue's Avatar
Default Re: (Built B16A)
i was about to say the same thing. You can't switch back unless you are running stock injectors
Old Nov 27, 2004 | 06:57 AM
T-RO's Avatar
Yeah I did it. heres my write up about it from a while ago...
https://honda-tech.com/zerothread?id=729204
Old Nov 27, 2004 | 08:22 PM
Built B16A's Avatar
Default Re: (T-RO)
well, its a succsess...
i went to radio shack, and looked at the switches, and i saw your little PC board one, but i was really feeling the fact of having the switch on the case, so i made it happen.
i put the switch up and to the right, cuz thats were the most space was, and i left enough wire to take the plate off and kick it to the side, and the wire i used wasn't like braided, it was solid... feels really solid.
what do you guys think?
Modified by Built B16A at 4:02 PM 11/28/2004
Old Nov 27, 2004 | 08:36 PM
adseguy's Avatar
GJ
Old Nov 28, 2004 | 07:30 AM
SOHC_MShue's Avatar
looks clean man
Old Nov 28, 2004 | 07:45 AM
EJ1 wilcox's Avatar
Default Re: (SOHC_MShue)
That looks really nice
What are you going to do about the injector problem as stated before?
You don't want to turn that thing off once you install the new injectors...
Old Nov 28, 2004 | 07:51 AM
Triscuit's Avatar
cant you just cut the jumper separate it then solder it back when need I know it sounds like a lot of work but......
Old Nov 28, 2004 | 12:44 PM
Built B16A's Avatar
Default Re: (Ronin EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ronin EG6 &raquo;</TD></TR><TR><TD CLASS="quote">cant you just cut the jumper separate it then solder it back when need I know it sounds like a lot of work but......</TD></TR></TABLE>
to me, that was a pain in the ***... and it honestly took me about 10 mins to put in this switch, cut me a quick hole, and then 4 soilder points.. peice of cake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">What are you going to do about the injector problem as stated before?</TD></TR></TABLE>
this is gunna be a little bit of a pain in the ***.. but, since im going to run those 450's that need a resistor box, im going to go ahead and use some OBD0 B16 injectors, and swap them back and forth.. 240's/450's.. changing injetors is shitty.. but if i can get this bitch to run right, i have no other choice.
Old Nov 28, 2004 | 01:10 PM
bullz's Avatar
WowiE
Old Nov 28, 2004 | 03:50 PM
Bailhatch's Avatar
Default Re: (iLLestjr)
Pretty weak in my opinion. It's a ******* "blow your **** up switch" that dangles off of the side of the ECU. It's too easy to accidentally open the switch. Putting one inside of the case makes far more sense to me. Quality work though
Old Nov 28, 2004 | 03:52 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Bailhatch)
^^^^you always make me laugh. i fell out of my chair
Old Nov 28, 2004 | 03:58 PM
Built B16A's Avatar
Default Re: (wantboost)
its at the very top, and if the ECU is mounted.. its hardley easy to switch... and the actual rocker inside the switch is pretty damn stiff... i dont' think i'll ever have a problem.
Old Nov 28, 2004 | 04:00 PM
wantboost's Avatar
Who is Mr Robot?
but dont say adam didnt warn you, lol
Old Nov 28, 2004 | 04:29 PM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">but dont say adam didnt warn you, lol</TD></TR></TABLE>
if i ever happens, i'll post it up, and tell everyone you told me so. lol
Old Nov 30, 2004 | 07:50 PM
mtber's Avatar
If you don't feel confident making a binfile for your setup, just im me I will hook you up.
Old Nov 30, 2004 | 10:21 PM
DefiantGSR's Avatar
Default Re: (mtber)
just reburn with stock bin and change the injector multiplier if you have aftermarket injectors.
Old Nov 30, 2004 | 10:26 PM
Built B16A's Avatar
Default Re: (DefiantGSR)
well, soon i'll start messing with it again.. i just got it smogged today, so the turbo will go back on tomorrow and i'll start messing with these uberdata files.
if anyone is interested in my progress.. here's the link.
https://honda-tech.com/zerothread?id=1047560
Old Dec 2, 2004 | 03:56 AM
Built B16A's Avatar
well.. my switch fell short. after taking the top cover off a few times, it finally broke the connection, so i re-enginered the idea.
as seen in some other ECU's, i decided to use the side which is stationary.
this way the switch is untouched.
trial and error.. but this should be the ticket.
Old Dec 15, 2004 | 03:15 PM
99lsvtecauto's Avatar
u got any closer pics does this still work if u car did not have this ecu originally
