getting hot , turbo sohc
Old Nov 29, 2004 | 09:58 PM
alexsracing's Avatar
Default getting hot , turbo sohc
I was racing on the freeway when at about 125-130 the temp started to go up and when I got home I can hear the sound of steam or boiling water in the overflow tank. Did the head lift and the hg break its seal and need to be replaced?
car is a crx with a d16z6 tdo5h at about 6 psi
Old Nov 29, 2004 | 11:28 PM
racinskittle's Avatar
Default Re: getting hot , turbo sohc (alexsracing)
90% your headgasket went.
Old Nov 30, 2004 | 01:44 AM
89dxhunchback's Avatar
Default Re: getting hot , turbo sohc (racinskittle)
yep, by by head gasket, I see head studs in your future..
Hey Skittle !!
Old Nov 30, 2004 | 08:34 AM
how much do the arp headstuds run for the d16z6?
and a stock gasket price?
Old Nov 30, 2004 | 09:49 AM
VTC_CiViC's Avatar
Default Re: (alexsracing)
Congratulations, you're now an official D-series boost owner. Now please collect your things and head to the back to recive your headstuds
Old Nov 30, 2004 | 09:52 AM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexsracing &raquo;</TD></TR><TR><TD CLASS="quote">how much do the arp headstuds run for the d16z6?
and a stock gasket price?</TD></TR></TABLE>
About 100 bucks for ARPs and about 90 for a Cometic gasket.
Old Nov 30, 2004 | 09:58 AM
quicksol95's Avatar
Default Re: (tegunderpressure)
welcome to the world of a boosted d-series
Old Nov 30, 2004 | 10:24 AM
RyanEJ8's Avatar
I got my D16Y8 ARP head studs for like $90 from http://www.lightningmotorsports.com
Old Nov 30, 2004 | 10:54 AM
Default Re: (RyanCivic2000)
I use stock head gasket ( d16a6 ) with the $100 arps, but I already have low compression. The $90 cometic isn't MANIDITORY, but it will help by lowering the compression.
$130 total if you use the stocker
$190 toal with the cometic
You may wanna get new timing belt and a few other things while your that deep in the motor.
Has going to need a new intake gasket, $11.
Old Nov 30, 2004 | 11:03 AM
VTC_CiViC's Avatar
Default Re: (89dxhunchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89dxhunchback &raquo;</TD></TR><TR><TD CLASS="quote">I use stock head gasket ( d16a6 ) with the $100 arps, but I already have low compression. The $90 cometic isn't MANIDITORY, but it will help by lowering the compression.</TD></TR></TABLE>
9.6:1 (or 9.2:1 if you've got a Z6) is already perfectly fine for boost. Don't lower the compression via a HG, go with an OEM gasket and copper spray and you'll be fine *IF* you do it all correctly.
Old Nov 30, 2004 | 11:16 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89dxhunchback &raquo;</TD></TR><TR><TD CLASS="quote"> The $90 cometic isn't MANIDITORY, but it will help by lowering the compression.</TD></TR></TABLE>
not necessarily... you can get cometics in stock thickness... they're not all lower cr.
Old Nov 30, 2004 | 11:44 AM
Default Re: (M.A.R.C.)
If your going to get the stock thickness, its pointless to pay 3 times as much.... My A6 head gasket handles 10psi daily, and has seen 16-17psi spikes...
Old Nov 30, 2004 | 11:54 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89dxhunchback &raquo;</TD></TR><TR><TD CLASS="quote">If your going to get the stock thickness, its pointless to pay 3 times as much.... </TD></TR></TABLE>
It's pointless to pay that much period. OEM gasket all the way
Old Nov 30, 2004 | 12:11 PM
sohcT's Avatar
Default Re: (VTC_resurected_CiViC)
Cometic head gaskets all the way!
Old Nov 30, 2004 | 02:08 PM
Default Re: (sohcT)
Reusing the stock headgasket
Haha been holding 10psi fine. Damn thing even had 160K on it. I just dont know The only thing i do know is that it was free.
HEY 89DX!!!!
Old Nov 30, 2004 | 03:28 PM
93turbo16's Avatar
ha, maybe if you wouldn't off taken it up that high you might still have a headgasket in tact. If you drive the car normally it won't just blow out on you. Well atleast from my experience atleast. But ARPS and a new headgasket, 3 hours for the work, and you are back on the road for more boost.
Old Nov 30, 2004 | 05:00 PM
SOHC_MShue's Avatar
this has been the story of my life ever since i turbo'd my D.
Old Nov 30, 2004 | 07:07 PM
JDMs1eeper's Avatar
Default Re: getting hot , turbo sohc (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">this has been the story of my life ever since i turbo'd my D. </TD></TR></TABLE>
yup... ur about to replace it again too
hndacvc25493
Jan 15, 2012 04:19 PM
97elitehonda
Apr 29, 2007 08:22 PM
delsoldrew
Mar 13, 2006 12:29 PM
rextec
Oct 12, 2004 10:38 AM
ryu12341
Jun 27, 2002 09:59 AM
