vacuum lines--CONFUSING problem or no?
Old Nov 25, 2004 | 10:43 PM
jDMJeRk's Avatar
Default vacuum lines--CONFUSING problem or no?
I have a 90-91 teg (obd0 but switched to obd1) and I have to do all the vacuum lines to run the car NA for the time being to make sure that the motor is properly installed, no cels, break in period, ect. I need to figure out how to route the vacuum lines.....
Vacuum is vacuum right? Can I just T everything into one another? The reason I ask is because I have a revhard intake manifold and have one TWO vacuum sources, 1 for the breakbooster and the other for the main source of vacuum? (Im guessing thats whats thats for?
Is it ok just to tie everything together?
Old Nov 26, 2004 | 05:59 AM
sporkcrx's Avatar
Default Re: vacuum lines--CONFUSING problem or no? (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">Is it ok just to tie everything together?</TD></TR></TABLE>
Yea, as long as the source is after the throttle body
Old Nov 26, 2004 | 09:45 AM
jDMJeRk's Avatar
Default Re: vacuum lines--CONFUSING problem or no? (sporkcrx)
so there are not specific order for vacuumm lines, it just about making sure they are all connected?
WTF?? That sounds too easy.
SnlpeR
Mar 4, 2009 11:11 AM
tigueremalo
Apr 14, 2006 11:37 AM
Infinite Auto
Welding / Fabrication
10
Apr 24, 2005 02:16 PM
JDubya
Apr 12, 2004 07:48 AM
xci_ed6
Aug 10, 2002 05:35 PM
