UBERdata question
Old Nov 27, 2004 | 01:42 AM
BEEYOND's Avatar
Default UBERdata question
Ok I've always wondered how Uberdata worked...
Do I first burn a chip with a BURNER and put it in a p28 or obd1 rechipped ecu? Then dyno the engine setup with that chipped ECU??? If it doesn't work out good on the dyno. I can remap(fix the fuel/ign number in each cell) with Uberdata and then reburn the chip...put the chip back into the ecu and then REDYNO???
are those the steps I need to take or what???
I am used to AEM EMS where you tune right there right away type of deal!!! No kind of burning chips, etc etc....
Let me know as I might try Uberdata...haha it's free right!!!!
I also checked on the uberdata.com site and they don't tell you how exactly the system works...very broad details only..
PLEASE HELP!!!
Old Nov 27, 2004 | 02:11 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: UBERdata question (nicholashang87)
uberdata is basically a computer software that lets you alter the fuel and ignition maps (as well as other features), and then save all that information onto a "chip". but yeah, you're mostly correct.
Old Nov 27, 2004 | 06:19 AM
Burke's Avatar
Banned
Default Re: UBERdata question (AzntaggeR)
http://www.ecimulti.org/uberdata/
Old Nov 27, 2004 | 09:04 AM
Si Shane's Avatar
What the first two meant to say is YOUR DEAD ON.
Some uberpeople are developing a cable to be hooked into the socket that will allow you to tune in real time. Expect to see something involving that, hopefully sometime soon, for around $150.
Old Nov 27, 2004 | 09:53 AM
SOHC_MShue's Avatar
you pretty much got it right. Except i would get a wideband rather than spending money on dyno time. With a wideband you can do datalogging too with uber.
Old Nov 27, 2004 | 11:25 AM
N20civicB18's Avatar
Default Re: UBERdata question (SOHC_MShue)
What if you used a ROMulator? could you use it perminate?
Old Nov 27, 2004 | 12:23 PM
raene's Avatar
Default Re: UBERdata question (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">What if you used a ROMulator? could you use it perminate?</TD></TR></TABLE>
I think you mean "permanently". The Romulator supposedly doesn't save things after it's powered off, or at least it isn't guaranteed to save them.
Old Nov 27, 2004 | 12:33 PM
scartail's Avatar
Default Re: UBERdata question (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">What the first two meant to say is YOUR DEAD ON.
Some uberpeople are developing a cable to be hooked into the socket that will allow you to tune in real time. Expect to see something involving that, hopefully sometime soon, for around $150. </TD></TR></TABLE>
What would happen if your laptop crapped out will you were using it to emulate the program?
Old Nov 27, 2004 | 12:58 PM
Si Shane's Avatar
Default Re: UBERdata question (scartail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scartail &raquo;</TD></TR><TR><TD CLASS="quote">
What would happen if your laptop crapped out will you were using it to emulate the program?</TD></TR></TABLE>
Dunno
A search on uberforum for real time tuning and other such words would give you the proper threads to ask that. I'm sure they'd love to cover that one
I dont know if its like a real time chip burning, or if you just use the laptop to tune then burn a final chip.
Old Nov 27, 2004 | 01:16 PM
SOHC_MShue's Avatar
Default Re: UBERdata question (raene)
man using a romulator would make things so much easier. I found my self spending a lot of timing having to shut the car off, tune the maps, and then reburn another chip before logging again.
Old Nov 27, 2004 | 01:25 PM
beerbongskickass's Avatar
My buddy used his romulator both times I had my car tuned on the dyno. This was way back like 9 months ago using Uberdata 1.63 and the last time using Uberdata 1.65 re-pack 3. I have recently switched my maps to Uberdata 1.66 and everything is going great.
enemy no1
Engine Management and Tuning
Jan 12, 2011 10:02 AM
mtber
Jul 8, 2007 01:30 PM
AccordSleeperZzZ
Dec 22, 2006 10:37 AM
