For a supercharged setup... what is better?
Old Nov 28, 2004 | 02:04 PM
jbell's Avatar
Default For a supercharged setup... what is better?
it terms of reliability and power... what would be better to boost?
b16, jdm d15b vtec, or a b18b?
i tried searching for s/c setups and comparisons, and there isn't much info on it around here.
i know the d15 can take alot of hp over stock before things start to break.. but i hear the power is very limited with a stock motor... around 160ish to the wheels.
what would make more power, b18b or b16...
its use will be a daily driver. looking for a low 14, high 13 second car on street tires (2350lbs) (so i guess 185ish to the wheels?)
thanks to anyone who can answer this..
Old Nov 28, 2004 | 02:09 PM
11psiTurboSI's Avatar
Default Re: For a supercharged setup... what is better? (jbell)
b16 would make more hp but the b18b would make more torque.
Old Nov 28, 2004 | 02:21 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: For a supercharged setup... what is better? (9psiTurboSI)
either way, dohc rocks the box (bring it on, i have my flame suit and matching helmet)lol
Old Nov 28, 2004 | 02:24 PM
MooreBoost's Avatar
Default Re: For a supercharged setup... what is better? (wantboost)
I had two blower cars then when to turbo's and haven't looked back. I would seriously consider a turbo D16, cheap, and can make 200whp pretty easily.
Old Nov 28, 2004 | 02:27 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: For a supercharged setup... what is better? (tegunderpressure)
yea, blow up a d16, big deal, blow up a b16, grab your ankles and burn your wallet
Old Nov 28, 2004 | 04:45 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">I had two blower cars then when to turbo's and haven't looked back. I would seriously consider a turbo D16, cheap, and can make 200whp pretty easily.</TD></TR></TABLE>
i realize that turbo has more potential, however the upkeep and cost is what is steering me away. I don't want to do the budget **** setup with $25 dollar turbos and all that, I would want to do it right... and that wont happen for the price of a used blower....
Old Nov 28, 2004 | 05:24 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">and that wont happen for the price of a used blower.... </TD></TR></TABLE>
Ofcourse it will, how much do you have set aside for the blower? I guarantee you can get a turbo running for that price.
Old Nov 28, 2004 | 05:29 PM
wantboost's Avatar
Who is Mr Robot?
and make more power too, turbos have been proven to make more hp per dollar put into the system than a supercharger
Old Nov 28, 2004 | 05:51 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">and make more power too, turbos have been proven to make more hp per dollar put into the system than a supercharger</TD></TR></TABLE>
i dont dobut that. infact, i know its true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Ofcourse it will, how much do you have set aside for the blower? I guarantee you can get a turbo running for that price. </TD></TR></TABLE>
a used jrsc... say $1500.
Old Nov 28, 2004 | 07:00 PM
MooreBoost's Avatar
Used turbo- $250
JRC FMIC- $155
Piping- $255
FMU- $100
Fuel Pump- $90
Rank1Racing Mani- $240
Downpipe- $100
Filter- $30
Feed/Drain Lines- $70
=$1290
Everything but the turbo was figured with brand new pricing, so you could easily save substantially more just by shopping around, or spend the remainder and get a new turbo. My point is it can easily be done, and I know you will be happier with the results, and please note that is not a "ghetto" setup at all.
Old Nov 28, 2004 | 08:44 PM
jbell's Avatar
what about tuning, ecu (uberdata), blow off valve, fuel pump, wastegate, and guages (not really needed)
Old Nov 28, 2004 | 08:48 PM
wantboost's Avatar
Who is Mr Robot?
p28 ecu -$120 (give or take)
Chip burner $90
Supplies to chip ecu - $30
BOV - $130
Wastegate - 215
Old Nov 28, 2004 | 09:43 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">p28 ecu -$120 (give or take)
Chip burner $90
BOV - $130
Wastegate - 215</TD></TR></TABLE>
so, like i said it would be cheaper to go s/c...
i just cant decide if i should go d15b vtec s/c or go b16, and then s/c down the road.
Old Nov 29, 2004 | 02:40 AM
Tony the Tiger's Avatar
Go B16 for S/C...
Sometimes it is not about how much power the engine makes; the way that the engine effectively uses the power to accelerate the car through gearing, redine and powerband is equally important.
I can tell you straight up that the DOHC VTEC will beat the D-series in the gearing, redline and powerband department.
I rarely hear folks blowing up their B16's with a near stock engine and a bolt-on JRSC. Unless you start doing something stupid, or else, they last quite a while. JRSC's a a bit pricey, but they are worth the money for a simple straight install with barely any maintenance at all.
Old Nov 29, 2004 | 07:15 AM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">what about tuning, ecu (uberdata), blow off valve, fuel pump, wastegate, and guages (not really needed)</TD></TR></TABLE>
Just retard your timing and run on the rich side by reading your plugs and you will be fine. You can get a DSM BOV for 30 bucks, or an OBX one for 50. I included the fuel pump in my price and the turbo will be internally gated, an autometer boost gauge is like 30 bucks.
Scrapin4DR
47
Sep 27, 2005 05:49 PM
silvercivic15
Jun 17, 2005 11:33 AM
redINTEGRAdriver
Mar 25, 2005 08:53 AM
Brand
May 13, 2004 01:06 PM
PhatHardy
Apr 5, 2003 01:42 PM
