fire ring
Old Nov 25, 2004 | 08:13 PM
2SLO's Avatar
Default fire ring
well, ive got a tial 35mm wastegate and dont ahve a firering for it. pissin me off. the ring i have is "for a 38mm" and sits way too low out the bottom of the gate, and i can still see past the valve with that thing in there. cant even get a nut on the mani with that ring in there.. a couple people told me the 35 ring and the 38 ring are the same, but i dont see how. ive never seen a ring sit that far out the bottom of the gate. now i cant hardly build boost without a ring in there. anyone know the difference or what the hell is going on with this thing?
Old Nov 26, 2004 | 06:59 AM
m R g S r's Avatar
Default Re: fire ring (2SLO)
You sure it's not backwards? Mine sat out a little bit, but was drawn flush when I tightened the bolts that hold the WG to the manifold....
Old Nov 26, 2004 | 08:57 AM
leadfoot78's Avatar
Default Re: fire ring (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">You sure it's not backwards? Mine sat out a little bit, but was drawn flush when I tightened the bolts that hold the WG to the manifold....</TD></TR></TABLE>
My 40mm was the same way, it's probably done that way so it seals better.
Old Nov 26, 2004 | 10:24 AM
adseguy's Avatar
Default Re: fire ring (leadfoot78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leadfoot78 &raquo;</TD></TR><TR><TD CLASS="quote">
My 40mm was the same way, it's probably done that way so it seals better.</TD></TR></TABLE>
Yep that's the idea
Old Nov 26, 2004 | 04:01 PM
2SLO's Avatar
Default Re: fire ring (adseguy)
mine wont go down at all.
Old Nov 27, 2004 | 02:49 PM
hybridsol's Avatar
Make sure its not backwards... It only fits one way. The "step" part goes into the WG, the "flat" touches the manifold.
Old Nov 27, 2004 | 03:58 PM
2SLO's Avatar
Default Re: fire ring (hybridsol)
i know how it goes in, it just dosent. not with a hammer, not with a vise, not with bolts on the manifold.
Old Nov 27, 2004 | 04:18 PM
MooreBoost's Avatar
Then find a 35mm firering.
Old Nov 27, 2004 | 04:19 PM
2SLO's Avatar
Default Re: fire ring (tegunderpressure)
good one buddy. but i was asking if anyone knew if the 35 and 38 were different. aparently they are but i have been told lots of times that they were the same.
Old Nov 27, 2004 | 04:41 PM
MooreBoost's Avatar
I can tell you the sky is red, can't I? Open your eyes.
Old Nov 28, 2004 | 01:31 PM
2SLO's Avatar
tell me whatever you want. but read the correct question first.
MalcolmV8
Apr 19, 2012 08:35 AM
powerdbygarrett
Jul 18, 2007 01:54 AM
Metal Head
May 4, 2006 05:43 AM
dan_w_82
Mar 25, 2005 10:38 PM
Cramerox
May 20, 2003 01:27 PM
