Need Help PLEASE!!Wastegate issues
Old Nov 29, 2004 | 05:35 PM
jdmfun99's Avatar
Default Need Help PLEASE!!Wastegate issues
How many pounds of boost can a Tial 38mm waset gate handle?..is it good for a 600hp car??Can it handle high boost????
PLEASE HELP
THANKS GUYS!!!!!!!!!!!!!!!!!
Old Nov 29, 2004 | 07:01 PM
adseguy's Avatar
Default Re: Need Help PLEASE!!Wastegate issues (jdmfun99)
The lower the boost the bigger the wastegate needs to be. That's the general rule.
But for high horsepower cars that run 600WHP then a lot more exhaust gas is probably made and so a bigger wastegate is needed even if it's high boost. I'm sure some people with 600WHP beasts will chime in.
Old Nov 29, 2004 | 07:42 PM
lanojp1's Avatar
Default Re: Need Help PLEASE!!Wastegate issues (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">The lower the boost the bigger the wastegate needs to be. That's the general rule.
i thought that rule only applied when you are running a hella big turbo...?
Old Nov 29, 2004 | 09:31 PM
adseguy's Avatar
Default Re: Need Help PLEASE!!Wastegate issues (lanojp1)
I don't see how? I mean it's harder to bypass gases away from a smaller turbo to make lower boost then it is to bypass gases in a bigger turbo for the same same boost....right? That's why internal wastegate turbos boost creep at the higher RPMS in lower boost setups.
I'm not sure about when to get a larger WG when you are looking at 600WHP if it's even necessary to get a larger WG.
Old Nov 30, 2004 | 03:27 PM
jdmfun99's Avatar
anybody else?
Old Dec 1, 2004 | 05:06 PM
jdmfun99's Avatar
HELP
Old Dec 3, 2004 | 06:02 PM
jdmfun99's Avatar
so can a 38mm handle 600 up whp????????
Old Dec 3, 2004 | 10:00 PM
PrettyLude's Avatar
normally i see people use a bigger wastegate for that kind of power level, 38mm isn't gonna cut it
Old Dec 3, 2004 | 10:11 PM
pimpintyperintegra's Avatar
i am going for a good deal more than 600 whp and i plan on using the tial 44mm
it should handle that boost/power level nicely
and it is v-band which is very nice as well
Old Dec 3, 2004 | 10:37 PM
Garcia-Racing's Avatar
My HKS did. Not too familiar with TIAL though......sorry.
Old Dec 3, 2004 | 10:56 PM
your HKS...what size? same size as the one in question?
Old Dec 6, 2004 | 02:32 PM
jdmfun99's Avatar
Default Re: (pimpintyperintegra)
ttt
Old Dec 6, 2004 | 05:33 PM
HKS standard 40mm w/ 1 bar spring . For sale, too.
ExVtec
Dec 29, 2008 10:52 AM
DrivinVtec
Jun 26, 2007 03:25 PM
ilikebigbutts
Dec 20, 2006 05:46 PM
JDM_EH2
Dec 24, 2005 06:04 AM
