turbo question
Old Nov 26, 2004 | 11:29 AM
Honda2NRperson's Avatar
Default turbo question
i just put a drag gen three turbo kit on my 94 GSR and when I hit the gas to the floor it falls on it's face, so to speak and it also backfires when I shift at redline, I have 310cc injectors and my electronics are stock, I called speedquest and they told me that I need an Apexi VTEC controller, im not getting the performace I should be any help would be great !
Old Nov 26, 2004 | 01:34 PM
Elemental's Avatar
stock electronics meaning... you havent gotten it tuned yet or what?
Old Dec 2, 2004 | 11:31 PM
Default Re: (Elemental)
yea it just has the stock ECU and I havent had the turbo tuned.
at half throttle it acclerates decently but at WOT it doesnt go anywhere it's like the car gets too much gas. 255LPH pump and 310cc injectors cause this.
Old Dec 3, 2004 | 05:15 PM
platinum00's Avatar
Default Re: (Honda2NRperson)
what kinda engine management are you running then if you have a stock ecu. does the drag kit come with a fmu or a piggy back system.
a fuel pump and injecters is for sure not safe with no other engine management.
what would you need a vtec controller for. did they recommend you run the afc hack or something. a vtec controller will not help you out at all.
it sounds like you need some engine mangement and a tune. i would not drive you car like this untill you figure out what is going on. it's super easy to pop your motor with a turbo if you dont have your sh*t setup right.
platinum.
Old Dec 3, 2004 | 10:05 PM
PrettyLude's Avatar
you need something to control the 310 injectors
Old Dec 3, 2004 | 10:10 PM
CivicEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda2NRperson &raquo;</TD></TR><TR><TD CLASS="quote">yea it just has the stock ECU and I havent had the turbo tuned.
at half throttle it acclerates decently but at WOT it doesnt go anywhere it's like the car gets too much gas. 255LPH pump and 310cc injectors cause this. </TD></TR></TABLE>
You need a FMU until you get a EMS...
Old Dec 3, 2004 | 10:40 PM
Groovinator's Avatar
tune that **** quickly.
Old Dec 4, 2004 | 06:52 PM
Default Re: (platinum00)
yes the kit came with a FMU.
DARKSIDE_TEG
Sep 23, 2005 05:42 PM
thefazio
Jul 29, 2005 01:36 PM
lucidvtec
Jun 28, 2005 12:37 PM
96dcek
Aug 24, 2004 05:48 PM
speedfrk69
Apr 13, 2004 03:50 PM
