SC61 which wheel..???
Old Nov 29, 2004 | 05:05 AM
DUB20VT's Avatar
Default SC61 which wheel..???
I am buying a Precision SC61.Using a .63 exhaust housing.The turbo will be used on a 2.0l 16V engine with a compression of 9.0:1. I wanna make over 500WHP .
Can anyone tell me whats the difference between the following SC61 combinations.
SC61 T3/T4 -6
Compressor: Wheel Inducer: 2.416" Wheel Exducer: 3.227" Wheel Trim: 56 Inlet Size: 3" Outlet Size: 2"
Turbine: Wheel Style: T04 Wheel Inducer: 2.920" Wheel Exducer: 2.542" Wheel Trim: 76 A/R: .63
Max HP: 680
SC61 T3/T4 -4
Turbine: Wheel Style: T04 Wheel Inducer: 2.920" Wheel Exducer: 2.420" Wheel Trim: 69 A/R: .63
Max HP: 680
SC61 T3/T4 -2
Turbine: Wheel Style: T350 Wheel Inducer: 2.920" Wheel Exducer: 2.420" Wheel Trim: 76 A/R: .63
Max HP: 680
Thanks.!!
Old Nov 29, 2004 | 05:19 AM
M.A.R.C.'s Avatar
Default Re: SC61 which wheel..??? (DUB20VT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUB20VT &raquo;</TD></TR><TR><TD CLASS="quote">I am buying a Precision SC61.Using a .63 exhaust housing.The turbo will be used on a 2.0l 16V engine with a compression of 9.0:1. I wanna make over 500WHP .
SC61 T3/T4 -6
Max HP: 680
SC61 T3/T4 -4
Max HP: 680
SC61 T3/T4 -2
Max HP: 680
Thanks.!!</TD></TR></TABLE>
Well the first two are straight T4's obviously. IMO if you wanna go for over 500whp a T350 SC61 would be good enough.
Old Nov 29, 2004 | 05:31 AM
DUB20VT's Avatar
Default Re: SC61 which wheel..??? (M.A.R.C.)
Hey Mark,
ok let me give you the full picture.I am busy with a 2.0l 20v vw motor and a 2.0l 16v engine.Both running 9.0:1 compresion.
both motors will be reved to 8200rpm.
1.Which wheel will make more power...???
2.Which wheel will make the turbo come into boost sooner..?
thanks man.
Old Nov 29, 2004 | 05:28 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUB20VT &raquo;</TD></TR><TR><TD CLASS="quote">Hey Mark,
thanks man.
1. T04 76 trim (P-trim)
2. T350
as per Rod from Precision:
The T350 wheel rates the SC61 @ ~620hp
The T04 69 trim brings that up to ~650hp
And the T04 76 trim brings that up to ~680hp
i think u'd be fine with the T350 one honestly. The T04 wheels will work and I doubt it would be THAT laggy on a 2.0L but you could easily reach your goals with the T350
Old Nov 29, 2004 | 11:54 PM
DUB20VT's Avatar
Thanks for your input.
Well this is what we are going with. We are going to use a SC61 with AR70 E compressor housing and a .63 exhaust side with a t350 76 trim wheel for a 2.0l 16v engine. And a SC61 with S compressor housing and a .63 exhaust with T04 76 trim wheel for a 2.0l 20v engine.
So be interesting to see what numbers we get.
l8r
Old Nov 30, 2004 | 04:43 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUB20VT &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your input.
l8r</TD></TR></TABLE>
the T04E housing is a .60 A/R, the T04S housing is .70 a/r and it's like ~$100 upgrade to go to the S housing.
Old Nov 30, 2004 | 06:08 AM
DUB20VT's Avatar
Right you are.Got a bit mixed up there.
xero_xero
May 4, 2010 08:05 PM
kccord
Nov 5, 2009 09:11 PM
Dasanib20T
Oct 16, 2008 12:40 AM
-Trinitron-
Feb 3, 2004 08:45 AM
