What Happened?
Old Nov 29, 2004 | 02:46 PM
Ls InTeGrA RaCeR's Avatar
Default What Happened?
Ok here's what's up. I took my turbo'd Ls for a long run and opened it up at 120mph (me being a dumbass). At 120mph the car felt like it hit the governor (spelling) so I let off. Next thing I know my car is running like ****. I drove it home, checked the oil and added a little since it was reading low. I started the car back up and it was still shitty. I popped the hood and the motor was shacking. Is this a Rod or just a Rod Bearing? I know its one of the two (from my knowledge).
Old Nov 29, 2004 | 02:52 PM
lanojp1's Avatar
most likely its a rod bearing...my friend has spun 4 in the past month in his d15...
Old Nov 29, 2004 | 02:57 PM
Johnyquest's Avatar
Default Re: (lanojp1)
You probably melted a piston. That's what mine did. I hope not, though.
Matt
PS- Is it smoking?
Old Nov 29, 2004 | 03:04 PM
gt35r's Avatar
Default Re: (Johnyquest)
take the spark plugs out and look into the holes with a flash light or something...then check the oil....listen for knocking...you sure did mess something up tho..
Old Nov 29, 2004 | 05:55 PM
Default Re: (gt35r)
there is no smoke anywhere. just a lot of noise.
Old Nov 30, 2004 | 01:38 AM
Default Re: (Ls InTeGrA RaCeR)
anyone else have an idea?
Old Nov 30, 2004 | 02:14 AM
hondaguyef's Avatar
What kind of noise it's making would be helpful to know.
Phil
Old Nov 30, 2004 | 04:00 AM
nsxmatt's Avatar
Default Re: What Happened? (Ls InTeGrA RaCeR)
Nobody is going to be able to know for sure what it is without looking at it or knowing more info. It could be something as simple as a fouled plug or serious like cracked ring lands, sleeve, blown head gasket, ect. Post your complete setup and then go pull your plugs and look at them.
Old Nov 30, 2004 | 02:09 PM
Default Re: What Happened? (nsxmatt)
Its a stock Ls Motor with a Full Greddy Kit including the RC310 Injectors. I don't know what else to tell you.
Old Nov 30, 2004 | 02:37 PM
11psiTurboSI's Avatar
Do a compression test...
Old Nov 30, 2004 | 07:33 PM
Default Re: What Happened? (9psiTurboSI)
To be honest.....I'm affraid of doing more damage just by starting the car. It wouldn't last through a compression test. Its gotta be something rod related.
Old Nov 30, 2004 | 07:37 PM
Muckman's Avatar
Moderator in Chief
I bet you just melted a spark plug. Now its running on 3 cylinders. It happens all the time when the EGTs get high on long boost runs.
Old Nov 30, 2004 | 07:38 PM
93turbo16's Avatar
just check everything, spark plug wires on the dizzy, lol. but you could take the manifold off and look in there with like a little light and mirror thingy..
Old Nov 30, 2004 | 07:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR &raquo;</TD></TR><TR><TD CLASS="quote">To be honest.....I'm affraid of doing more damage just by starting the car. It wouldn't last through a compression test. Its gotta be something rod related.</TD></TR></TABLE>
I bet you spun a rod bearing!
Old Nov 30, 2004 | 07:54 PM
m R g S r's Avatar
Default Re: What Happened? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I bet you just melted a spark plug. Now its running on 3 cylinders. It happens all the time when the EGTs get high on long boost runs.</TD></TR></TABLE>
I bet a piston would melt before a spark plug. . .
You don't need to start the car to do a compression test BTW. . .
Old Nov 30, 2004 | 09:20 PM
Muckman's Avatar
Moderator in Chief
Default Re: What Happened? (m R g S r)
You think so? Its not hard to melt the tip of a spark plug.
Old Nov 30, 2004 | 09:26 PM
This One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
ehh, sometimes not
Old Nov 30, 2004 | 09:30 PM
mtber's Avatar
I have seen 2 vehicles melt spark plugs before damaging the piston...
Old Nov 30, 2004 | 09:39 PM
Matgallis's Avatar
Default Re: (mtber)
drop the oil pan and check fo shavings?
Old Nov 30, 2004 | 09:47 PM
G
sh!t happens.
Default Re: (mtber)
is it making a loud KNOCKING noise? what psi were you on. does it get louder as you rev it up?
Old Nov 30, 2004 | 11:39 PM
jdm91integ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">
I bet you spun a rod bearing!</TD></TR></TABLE>
Old Dec 1, 2004 | 04:32 AM
nsxmatt's Avatar
Default Re: What Happened? (jdm91integ)
Just pull the plugs for crying out loud! 2 minutes!
Old Dec 1, 2004 | 06:41 AM
PM-Performance's Avatar
i thought i spun a rod bearing at one time. then i really listened to it closely and it was in the head. Stupid valve tapet screw fell off. . The rocker was just flapping around.
Do some investigation man. Check to see where the sound is coming from , it its coming from the bottm end then its prob rod knock.
Old Dec 1, 2004 | 06:22 PM
Default Re: What Happened? (itr206)
Well I finally got everything apart today.....turns out I'm it for a little fun. I have a bad wrist pin (I think that's right) and ontop of that I have a few loose valves. So after $80 worth of parts (new #4 piston ring and wrist pin) and some cleaning everthing should be good. I checked the rod bearings and they were fine, not even a scratch.
Old Dec 1, 2004 | 07:34 PM
*Boostwerks*'s Avatar
Loose valves? do you mean they need an adjustment?
And what do you mean by Bad wristpin?
