Building B16 for Turbo setup
Old Feb 20, 2005 | 07:00 PM
hybrid0006's Avatar
Default Building B16 for Turbo setup
Heres my build:
Stock B16A2 head with an older JDM b16 block
Precision SC34 Turbo
RC 440cc Injectors
Walbro 255lp hp Fuel Pump
UberData Basemap (untuned, waiting for it to get tuned)
Tial 38mm Wastegate
TurboX BOV
JRC 6in Intercooler
I am going to be hopfully moving soon to goto college and I want a car that can run fine on the street and I won't have to much problems with. I don't need a huge amount of boost, I would be satisfied with 10psi probably. I am just concerned about the stability of my block because of its age and the wear and tear the turbo is putting on it. So what I am trying to find out is what I should do as far as building my block or buying a different block, or what not, just to get it to run safe and not having to be worried and to get it to run about 10psi. Any ideas?
Old Feb 20, 2005 | 07:16 PM
TheShodan's Avatar
Moderator
IF tuned well with your system. I see no reason why it shouldn't run reliably for years. Just don't get nutz with "fiddling" with areas you might not know well, such as timing adjustment etc., and you should be fine.
Old Feb 20, 2005 | 09:10 PM
hybrid0006's Avatar
Default Re: (TheShodan)
Don't you think I should build the block a little bit?
Old Feb 20, 2005 | 09:25 PM
PrettyLude's Avatar
one thing at a time, worry about getting it tuned first, then if you have money buy a shortblock and build it
Old Feb 20, 2005 | 09:43 PM
hybrid0006's Avatar
Default Re: (PrettyLude)
LS, GSR, B20???
Old Feb 21, 2005 | 02:35 AM
integlspwr2k's Avatar
Default Re: (hybrid0006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid0006 &raquo;</TD></TR><TR><TD CLASS="quote">Don't you think I should build the block a little bit?</TD></TR></TABLE>
if tuned correctly you can make gobs of power on a stock block stock head.
thats what i plan on doing.
Old Feb 21, 2005 | 05:14 AM
rmcdaniels's Avatar
If you're just running 10 PSI and you have a good tune, then stock sleeves and internals should be fine. If you start detonating, then it will quickly die.
Old Feb 21, 2005 | 05:43 AM
B18c1turboedEK's Avatar
Default Re: (rmcdaniels)
YOu need to change those home depot couplers, they will blow off easily!!!
Old Feb 21, 2005 | 01:52 PM
hybrid0006's Avatar
Default Re: (B18c1turboedEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1turboedEg &raquo;</TD></TR><TR><TD CLASS="quote">YOu need to change those home depot couplers, they will blow off easily!!! </TD></TR></TABLE>
lol, where can I pick up some "better" ones??? website link er somthing plz? thx
Old Feb 21, 2005 | 01:56 PM
primeredbeast's Avatar
i have pretty much the same setup that you have and i bet that you would be satisfied with 8 lbs of boost or so on a street car that will make the tires spin even at that low of boost just my opinion
Old Feb 21, 2005 | 04:58 PM
message flamenco-t he got some 4ply shiney style silicone couplers and reducers. Best prices on the internet, hands down..
Old Feb 21, 2005 | 05:03 PM
mtber's Avatar
Default Re: Building B16 for Turbo setup (hybrid0006)
You may max out those 440s if you plan on making upper 200s.
Old Feb 21, 2005 | 06:26 PM
hybrid0006's Avatar
Default Re: Building B16 for Turbo setup (mtber)
Hmm, I talked to people at shops and they think that b16 wont hold up. Hmm...
Old Feb 22, 2005 | 06:31 AM
tgreaves's Avatar
I used them with t-bolt clamps and they worked great.. If you do have one blow off then spray some hairspray on the pipe and put it back on..
Old Feb 22, 2005 | 10:08 AM
hybrid0006's Avatar
Default Re:
Have u guys ever heard of the inside of pipes rustin the the rust flaking off and going into the engine as powder form?
Old Feb 22, 2005 | 02:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">You may max out those 440s if you plan on making upper 200s.
not if you up fuel pressure..
Old Feb 22, 2005 | 02:18 PM
H.A.R.T B18C1EG6's Avatar
looks good
justinboost
Dec 24, 2012 06:41 AM
walo
Nov 14, 2011 01:15 PM
highroller92
Feb 22, 2011 12:55 PM
Topdawgg
Oct 4, 2005 06:27 AM
sleeperHatch
May 20, 2005 06:28 PM
