can some one give me a conversion from bar to psi?
for instance how much psi is 1.4 bar, .8 bar, and so on, and what bar is 10 psi and so on? thanks guys
Re: can some one give me a conversion from bar to psi? (tallblondkid)
did you try searching on google? I had found a sheet that had it all listed out a few years back. If I still had the link i would post it for you
1 BAR = 14.5 psi
Multiply BAR amount X 14.5 to go from Bar to PSI
1.4Bar X 14.5=20.3 PSI
.8bar X 14.5= 11.6PSI
To go from PSI to bar is the opposite..you divide by 14.5
10PSI / 14.5 = .68BAR
Re: can some one give me a conversion from bar to psi? (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">1 BAR = 14.5 psi
10PSI / 14.5 = .68BAR</TD></TR></TABLE>
Some people will say 1 BAR = 14.7psi (atmospheric)
Re: can some one give me a conversion from bar to psi? (mrx)
Re: can some one give me a conversion from bar to psi? (slow poke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke »</TD></TR><TR><TD CLASS="quote">
You are 100% right my friend 14.5psi=1bar</TD></TR></TABLE>
I know, im a Scuba Diver and my life depends on me knowing these things..
Re: can some one give me a conversion from bar to psi? (tgreaves)
Few others so you can find a good conversion for other types.
1mm=. 03937 inch
1 inch = 25.4 mm
1kg/cm^2= 14.223344psi
1 psi= .070307 kg/cm^2
1kg/cm^2 = 98.0665 kPa
1kPa = .0101972 kg/cm^2
Temp
(___*C x 1.8) + 32 = _____*F
(___*F - 32) / 1.8= _____*C
Liquid Flow
1 lbs./hr = 10.5 cc/min
1cc/min = .095238 lbs./hr
Speed
1 mph = 1.609344 km/h
1 km/h = .6213712 mph
These were taken from Greddy, useless info, maybe but o well.
1mm=. 03937 inch
1 inch = 25.4 mm
Temp
Liquid Flow
Speed
