vacuum line question?
Old Feb 16, 2005 | 03:40 PM
sir00's Avatar
Default vacuum line question?
im going to be using the intake manifold as a vacuum source for my wastegate and my question is what do i do with the hole on my compressor outlet.....do i plug it or do i leave it open?
Old Feb 16, 2005 | 03:50 PM
96-EJ6 B18C's Avatar
Default Re: vacuum line question? (sir00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir00 &raquo;</TD></TR><TR><TD CLASS="quote">im going to be using the intake manifold as a vacuum source for my wastegate and my question is what do i do with the hole on my compressor outlet.....do i plug it or do i leave it open?</TD></TR></TABLE>
If it was me I would just use the port on the compressor for the WG boost source and cap the one on the back of the mani. The shorter the vac lines are to the WG the less it will spike...at least that is what I noticed.
What is your reasoning for wanting to use the back of the mani?
If you really want to use the manifold one just plug the hole on the compressor otherwise you'll have a boost leak.
Old Feb 16, 2005 | 03:52 PM
Cray91's Avatar
Yeah plug the one on the housing. That will just be whistleing all the time
Old Feb 16, 2005 | 06:43 PM
sir00's Avatar
Default Re: (Cray91)
thanks for the input guys......I appreciate it.
del_orson
Feb 3, 2005 03:50 PM
Rod.
Apr 14, 2004 11:24 AM
k2civic
Jan 22, 2004 06:08 PM
BoostedD15B7
Dec 8, 2002 05:30 PM
KLN
Jul 1, 2002 11:16 AM
