Downpipe too Close to Alternator???
Old Feb 17, 2005 | 07:48 PM
STL01Civic's Avatar
Default Downpipe too Close to Alternator???
From looking at the pic. Does it too close to the altnator? The tech guy said the reason my alt. is going bad, is because the downpipe is giving off 300F temp to the altnator.
Can I wrap around my downpipe with some thermal warp or heat wrap / ???
Old Feb 17, 2005 | 07:50 PM
Ri5e's Avatar
Default Re: Downpipe too Close to Alternator??? (STL01Civic)
You can fabricate a heatsheild for the alternator
Old Feb 17, 2005 | 07:53 PM
mrbsponge's Avatar
like havin sex with a dirty woman, just wrap that bad boy!
Old Feb 17, 2005 | 08:51 PM
STL01Civic's Avatar
Default Re: (mrbsponge)
http://cgi.ebay.com/ebaymotors...33631
You think 1 of those (or more) should do the trick??? I am thinking about wraping the whole downpipe.
Old Feb 17, 2005 | 09:20 PM
Loco Honkey's Avatar
The DP in my AllTrac is about five times further away than that, but Toyota still put a heat shield on the alternator went so far as to add a small scoop on the hood to duct cooling air towards it.
I think their reasoning was something along the lines of retaining that whole Toyota reliability image... I can't recall, though.
Old Feb 17, 2005 | 09:22 PM
Default Re: (STL01Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STL01Civic &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...33631
You think 1 of those (or more) should do the trick??? I am thinking about wraping the whole downpipe.</TD></TR></TABLE>
That's a good way to rot your downpipe. How about an actual heat shield? Some 22 gauge mild steel bent up and held a half inch from the DP would work wonders.
Old Feb 18, 2005 | 08:45 AM
msmotorsports's Avatar
Heat wrap works extremely well to reduce under hood temps and keep the heat in the pipes. You won't even need a heat shield if you properly wrap the DP.
Old Feb 18, 2005 | 09:49 AM
W O T's Avatar
Default Re: (msmotorsports)
Id do both, if you have a vice, drill, hammer and a small sheet of metal you can easily bang out a heatshield, but thermal wrap is cheap ****, but Ive read many things about it causing SS to erode and cause cracking and such
Old Feb 18, 2005 | 12:18 PM
Finland's Avatar
Default Re: Downpipe too Close to Alternator??? (TurboSmart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSmart &raquo;</TD></TR><TR><TD CLASS="quote">You can fabricate a heatsheild for the alternator</TD></TR></TABLE>
^^Exactly!! Leave the pipe alone, and just make a shield for the alt.
Old Feb 18, 2005 | 12:23 PM
dennis's Avatar
Mines about that close (or closer) and caught in a downpipe/dump tube sammich. I just wrapped the segment that runs next to it with wrap. No problems yet... *crosses fingers*
Old Feb 18, 2005 | 12:27 PM
DaX's Avatar
DaX
Loved
Community Favorite
I'd go with the shield...too many worries I've heard of with wrapping exhaust members.
Old Feb 18, 2005 | 12:34 PM
dennis's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">I'd go with the shield...too many worries I've heard of with wrapping exhaust members.</TD></TR></TABLE>
Yeah, I've *heard* stuff too, just never seen or witnessed it myself. Either way, I spent about $50 at most on my downpipe and about 2 hours or so cutting/fitting/welding - so no biggy to me.
Old Feb 18, 2005 | 12:36 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (dennis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, I've *heard* stuff too, just never seen or witnessed it myself. Either way, I spent about $50 at most on my downpipe and about 2 hours or so cutting/fitting/welding - so no biggy to me.</TD></TR></TABLE>
Then wrap that bitch.
Old Feb 18, 2005 | 12:49 PM
dennis's Avatar
Check out http://www.racepartsolutions.com/ - it's cheaper and I like supporting these guys because they have good prices and always have what I need
SubSero
Acura TSX
Aug 6, 2017 04:21 PM
accord2nrz
Mar 17, 2008 05:49 AM
RTW DC2R
Apr 13, 2006 06:20 PM
m00tjam
Jan 7, 2005 02:36 PM
freeofparanoia
Oct 20, 2003 08:51 PM
