No fuel or spark ? >>
Old Feb 19, 2005 | 02:29 PM
platinum00's Avatar
Default No fuel or spark ? >>
ok car is ready to go. 180 compression across the board.
i got no fuel or spark though. i relocated my battery to the trunk, but that has got to be hooked up right cause all the lights work, the motor turns over etc...
i check the fuses under the hood and they look good. my fuel pump is not even turning on .
i had a new basemap burned for this setup. does the ecu have anything to do with the pump not coming on. i didnt think it did.
any sugestions.
platinum.
Old Feb 19, 2005 | 02:40 PM
EG1.8cT68's Avatar
What model car do you have, I am assuming a Ek based on your avatar. If the pump isn't coming on, and you have no spark, I would say main relay. You need to check to see if the ECU is getting power if it is your chip may be messed up.
Old Feb 19, 2005 | 02:44 PM
platinum00's Avatar
Default Re: (EG1.8cT68)
the car is a 00 civic ek, with a p28 ecu and hondata. yes a ek though.
so the chip could cause that.
im going to swap my old chip in and see what happens.
i need to go get a new battery for my volt meter.
thanks for the reply.
anything else
platinum.
Old Feb 19, 2005 | 03:30 PM
platinum00's Avatar
Default Re: (platinum00)
ok so the main relay fuse #31 has no power with the ignition on.
this is a dumb question. but where is the main relay at. under the driver side dash ??
i guess i need to check the relay itself, but im assuming it has no power if the fuse does not..
platinum.
Old Feb 19, 2005 | 03:40 PM
platinum00's Avatar
ok, jesus,
i found the main relay, ******* thing is not hooked up. WTF
but i cant find the plug for it now. haha
i guess that's what i get for removing everything behind my dash this time.
does the plug for that go into the wiring harness.
platinum.
Old Feb 19, 2005 | 04:05 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">ok car is ready to go. 180 compression across the board.
any sugestions.
platinum.</TD></TR></TABLE>
yes, its somewhere underneath there, just keep looking
Old Feb 19, 2005 | 04:28 PM
platinum00's Avatar
Default Re: (PrettyLude)
i got it.
started right up. sounds great.
after the thermostate opened up a blew a coolant line off the head. no biggie.
brand new engine bay already wet, jesus.
little oil leak from the return line.
and its bounces from 2400 - 2700, when trying to hold at 2500.
i will fix that stuff tomarrow, change the oil already, and go see what this diff and new clutch feel like \\
platinum
Old Feb 19, 2005 | 05:33 PM
EG1.8cT68's Avatar
Okay glad to hear you got it working, now you owe me $78 for diagnostic help, you can make the check out to E-G-1, just kidding. Now tune it at a dyno and smoke some fools!
Old Feb 20, 2005 | 05:23 AM
platinum00's Avatar
hell yea man,
thanks for the quick help. i knew it was something stupid.
now if i get this damn bulkhead fitting on my pan to stop leaking i will be ready to roll.
platinum.
Old Feb 20, 2005 | 05:25 PM
EG1.8cT68's Avatar
Brake kleen it and JB weld!
ek9_ab
Feb 16, 2015 01:08 PM
donny420
12
Mar 14, 2010 03:56 PM
poncejose334
Jul 29, 2009 07:17 PM
JDMcivicSiEG6
10
Oct 20, 2008 07:25 PM
pleej
19
May 9, 2007 05:41 PM
