Another EGT question (searched)
Old Feb 17, 2005 | 03:14 PM
bk11383's Avatar
Default Another EGT question (searched)
ok so i've read and read about egt probe placement and what not. it seems that most people are using a 1600 degree probe. would it be over kill to get a 2200 degree probe? or should i get a 1600 degree and be done with it? also this is the gauge that im looking at getting along with the kit: http://www.42draftdesigns.com/...0.htm
anyone have luck with these? i already have the oil pressure and the boost gauge. i'm hoping that they will work decently as i have not been able to find any stories about these gauges.
Old Feb 17, 2005 | 05:12 PM
cnydc2's Avatar
Default Re: Another EGT question (bk11383)
I have never tried those gauges, but I have heard a bunch of good things about them.
Old Feb 17, 2005 | 06:34 PM
ProjectDarkBlack's Avatar
Default Re: Another EGT question (cnydc2)
i think EGT can go close to 2000 and i know it can go over 1600 so i i had to pick i would say 2200
Old Feb 18, 2005 | 04:07 AM
bk11383's Avatar
any other EGT gurus have comments? and also where can i get a 2200 degree probe anyway? i've found a couple of sites but they were kinda sketchy.
Old Feb 18, 2005 | 05:29 AM
B16Civic93's Avatar
wheres a good placement for the egt probe?
Old Feb 18, 2005 | 05:56 AM
turboteg2nv's Avatar
Default Re: Another EGT question (B16Civic93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bk11383 &raquo;</TD></TR><TR><TD CLASS="quote">any other EGT gurus have comments? and also where can i get a 2200 degree probe anyway? i've found a couple of sites but they were kinda sketchy.</TD></TR></TABLE>
I'm not exactly a guru but on my bro's talon the temp never really gets past 1500' even when he's romping it. Oh and by the way...i just happen to be selling an Auto-Meter Phantom 52mm EGT gauge and kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">wheres a good placement for the egt probe?</TD></TR></TABLE>
Should be put on the 3rd runner about 3-4 inches away from the block.
Old Feb 18, 2005 | 06:17 AM
XSIintegra's Avatar
Default Re: Another EGT question (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">i think EGT can go close to 2000 and i know it can go over 1600 so i i had to pick i would say 2200</TD></TR></TABLE>
Correct me if I'm wrong, but I've been under the understanding that anything over 800c/1500f means something is going wrong (i.e. going lean). You should never see temps in the 1100c/2000f range. Hell, a Greddy egt stops at 1200c/2200f.
Old Feb 18, 2005 | 06:30 AM
pissedoffsol's Avatar
25 Year Member
Default Re: Another EGT question (XSIintegra)
i never went over 850 celcius on my t3/t67 full race gsr in 100 degree heat on the dyno.
Old Feb 18, 2005 | 06:35 AM
01geeser's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSIintegra &raquo;</TD></TR><TR><TD CLASS="quote">
Correct me if I'm wrong, but I've been under the understanding that anything over 800c/1500f means something is going wrong (i.e. going lean). You should never see temps in the 1100c/2000f range. Hell, a Greddy egt stops at 1200c/2200f.</TD></TR></TABLE>
ive had mine hit 900c. egt's get pretty high when you run too rich. on a proper tune you wont really need an egt, but thats cuz i run a wide band 24/7.
Old Feb 18, 2005 | 07:15 AM
PrettyLude's Avatar
Default Re: Another EGT question (pissedoffsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">i never went over 850 celcius on my t3/t67 full race gsr in 100 degree heat on the dyno.</TD></TR></TABLE>
mines never got passed that too
Old Feb 18, 2005 | 07:19 AM
PrecisionH23a's Avatar
Under boost with proper ignition timing, you should see values from 750c-800c and 1380f-1500f. Anything higher than that, and you need to learn a little bit more about what EGT's mean. Where can you learn? Check this site out:
http://www.sdsefi.com/techegt.htm
BDaTurboTeg
Jun 18, 2008 02:40 PM
slooogsr
Oct 24, 2003 06:26 AM
VoltageLS
Sep 23, 2003 09:34 AM
aet6
Jul 26, 2002 05:21 PM
ceemarun
May 7, 2002 07:11 PM
