Bigger Injectors Needed?
Old Feb 19, 2005 | 07:18 PM
...emu...'s Avatar
Default Bigger Injectors Needed?
I boosted my stock b16a2 with a Drag turbo kit (T3/T4). When it came time to tune, it was extremely lean starting at VTEC, and it could only be tuned to 4psi. I was told that I needed bigger injectors (440cc) in order to make my car drivable to redline at 8psi. I was wondering if other people have had this problem or if anyone has any advice. Thanks in advance. Sorry if this is really basic....
Old Feb 19, 2005 | 09:08 PM
T4eg's Avatar
Default Re: Bigger Injectors Needed? (milanoturbosi)
If the drag kit has a FMU u dont need injecotrs. If u are running someother form of ems for example hondata, aem, etc u will need to get bigger injectors. I would go atleast 440 depending on the power u want to make.
Chris
Old Feb 19, 2005 | 09:19 PM
SpdFrk's Avatar
If your on a FMU u can get bigger injectors but your gonna need something to control them like a afc. Are u using a inline or a intank fuel pump?
Modified by SpdFrk at 2:07 AM 2/20/2005
Old Feb 20, 2005 | 01:05 AM
PrettyLude's Avatar
Default Re: Bigger Injectors Needed? (BlueHatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">If the drag kit has a FMU u dont need injecotrs. If u are running someother form of ems for example hondata, aem, etc u will need to get bigger injectors. I would go atleast 440 depending on the power u want to make.
Chris</TD></TR></TABLE>
Old Feb 20, 2005 | 01:56 AM
reaction360's Avatar
Default Re: Bigger Injectors Needed? (PrettyLude)
as someone else stated. if you're running the full drag kit then you're running an fmu. the fmu compensates for fuel when in boost. by just adding larger injectors, there will be nothing to control the bigger injectors at ilde and before boost. or even during boost for that matter. also,what disc is in the fmu? you can also up the fmu pressure if it's not already a 12:1 disc.
also, on my old b16, i was maxin out my 440's at 12psi
Old Feb 20, 2005 | 08:36 AM
...emu...'s Avatar
Well, I'm running an FMU with a 12:1 disc and an intank fuel pump. I also have a VAFC II so controlling the extra fuel shouldn't be a problem and since the most boost I'm ever planning on running is 8 psi I thought that the fmu would be enough to control my fuel. I'm just wondering because I really don't know much about cars and I don't want this shop to take me for more money. I've just always heard that the drag kit is complete so I was shocked when they said I needed the bigger injectors. Thanks again for the help.
Old Feb 20, 2005 | 08:54 AM
Default Re: (milanoturbosi)
the drag kit is a good complete kit. but the fuel management needs to be upgraded once u start boostin higher and making good power. if you already have a vafc2, you can ditch the fmu, missing link, and run some 440-550cc injectors. this would be called the "afc hack." you can do a search on afc hack and find many pages of info. on it. it works. it just doesn't do anything for timing and actually advances timing. I, myself run uberdata. you can go on the "uberdata" forums and do a search for the nearest local guy in your area and have that done.
Old Feb 20, 2005 | 09:03 AM
iv's Avatar
iv
I would get 440 or 550 injectors and run Uberdata or crome then you can get rid of the external fmu and you can tune your timing and fuel without a "Hack"
Old Feb 20, 2005 | 12:37 PM
tegon-gsr's Avatar
Default Re: (iv)
I will have 440 for sale in about two weeks for 170 shipped let me know.
Old Feb 20, 2005 | 02:06 PM
...emu...'s Avatar
tegon-gsr: what brand are they? How long have they been used? Thx.
boostedlude3g
May 26, 2004 01:43 AM
mtber
Jul 21, 2003 08:06 AM
BoostedD15B7
Sep 26, 2002 01:15 PM
TURBOED-TEG
May 8, 2002 06:33 AM
EF8SIR
Apr 13, 2002 12:33 PM
