can one use a walbro as an inline pump.
Old Feb 16, 2005 | 12:16 PM
The sweed's Avatar
Default is it ok to use a walbro as an inline pump??
Just like the topic says.. Will it work to use a walbro 255 lph HP pump mounted higher than the fueltank on the fuel line??. or will it only work in tank. Maybe have the stock fuel pump to feed the walbro pump. A friend of mine is asking me about this for his turbo converted bmw..
If it won´t work please help me out to pick a god inline pump for 450-500 HP
Modified by The sweed at 2:47 PM 2/16/2005
Old Feb 16, 2005 | 02:26 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: is it ok to use a walbro as an inline pump?? (The sweed)
I too have a Walbro 255lph, and from the looks of it I'm not sure you can use it as an inline pump because of the short plastic connection on the bottom. Remember that the only means of filtration is the external filter that is provided.
Old Feb 16, 2005 | 03:54 PM
Cray91's Avatar
You need a pup that is designed to go in-line. If it is for in-tank use, then that is where it needs to be.
Old Feb 16, 2005 | 10:24 PM
turtle-eg's Avatar
I think it can only be safe to use as an internal pump because the gas in the tank cools the pump down.
Why not try a NOS external inline pump? If that's not enough fuel, a Paxton or SX external would do.
Old Feb 16, 2005 | 10:47 PM
PrettyLude's Avatar
Default Re: is it ok to use a walbro as an inline pump?? (turtle-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">I think it can only be safe to use as an internal pump because the gas in the tank cools the pump down.
Why not try a NOS external inline pump? If that's not enough fuel, a Paxton or SX external would do.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cray91 &raquo;</TD></TR><TR><TD CLASS="quote">You need a pup that is designed to go in-line. If it is for in-tank use, then that is where it needs to be.</TD></TR></TABLE>
Old Feb 17, 2005 | 06:16 AM
JSpin's Avatar
there is a walbro 255 inline pump.........it's what i'll be using
Old Feb 17, 2005 | 07:40 AM
PrettyLude's Avatar
why don't you just get a nos inline or gm inline pump its the same thing and its cheaper
Old Feb 17, 2005 | 10:44 AM
JSpin's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">why don't you just get a nos inline or gm inline pump its the same thing and its cheaper</TD></TR></TABLE>
news to me, thanks
technine
May 22, 2009 05:38 PM
maddcrx
May 10, 2008 10:38 AM
97grnrs
Sep 27, 2007 06:54 AM
veejay
Jul 22, 2001 10:57 AM
