Boost Noobie question
Old Feb 20, 2005 | 03:38 AM
rwcdrums's Avatar
Default Boost Noobie question
Last summer I swapped a 94 jdm b18c into my 92 cx and soon will be boosting for the first time. I know this has probably been covered before but I'm looking to see what kind of #'s I can expect. Setup: 94 jdm b18c with lsd/tranny stock, Drag III turbo kit, 880cc injectors, walbro 255 fuel pump, hondata. I'm not sure if I left anything out or not. I'm wanting to run between 7 - 10lbs. First off is this a safe amount of boost to be running on stock internals? What kind of hp #'s can I expect? and one last thing. How well do the stock lsd's hold up under boost? Any help would be greatly appreciated!!
Old Feb 20, 2005 | 04:08 AM
Finland's Avatar
well tuned with 3" exhaust, expect ~300whp.
Old Feb 20, 2005 | 05:08 AM
rwcdrums's Avatar
Default Re: (Boondock Saint)
thanks, anyone else?
Old Feb 20, 2005 | 08:08 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Boost Noobie question (rwcdrums)
Considering you do have a higher compression motor you should be able to get around or over 300hp properly TUNED at lower boost levels. If I were you I would definitely upgrade the pistons and rods because you don't exactly know the condition of them until you open up the motor or it fails on you. I would suggest upgrading the clutch (if you haven't done so), fuel pump, fuel pressure regulator (stay away from those rail mounted types such as B&M), exhaust piping/muffler, etc.....Also, it wouldn't hurt to sleeve the block either...just a little insurance because DOWNTIME does SUCK!!!
Old Feb 20, 2005 | 08:14 AM
rwcdrums's Avatar
Default Re: Boost Noobie question (NVturbo)
Thanks for the advice. I do plan on changing the stock internals and sleeving the block but unfortunately I'm not rich and will probably have to wait until next year to do those upgrades. I just wanna make sure that until I go that route I will be ok running this setup. Thanks again for the advice!!
Old Feb 20, 2005 | 08:16 AM
NVturbo's Avatar
O.G. triple O.G.
Its all good. TAke it from me...I didn't get all the stuff on my setup over a weekend. Not all of us have rich parents that front the money for this expensive hobby.
Old Feb 20, 2005 | 09:03 AM
kabaroo's Avatar
dont you think 880 injectors are a little much for a stock motor?
Old Feb 20, 2005 | 09:06 AM
rwcdrums's Avatar
Default Re: Boost Noobie question (kabaroo)
I do but I got a great deal on them and I won't have to upgrade them for a while.
Old Feb 20, 2005 | 10:14 AM
Terrible One's Avatar
do a quick compression test and post up the numbers. around 300whp is what you should be shooting for on stock blocks.
HondAcura
Jul 17, 2006 11:54 AM
StrangerWitCandy
Feb 2, 2005 04:12 PM
EGB18C
Sep 23, 2004 08:55 PM
BoostedGSRBubble
Apr 20, 2003 12:32 AM
X2BOARD
Apr 18, 2002 10:51 AM
