What are you guys using for oil return line?
Old Feb 20, 2005 | 12:03 PM
Black R's Avatar
25 Year Member
Default What are you guys using for oil return line?
Is there something I can purchase from home depot or lowe's?
I have a ruptured oil return line and need to get back on the road asap...
Anyone?
Old Feb 20, 2005 | 12:46 PM
Terrible One's Avatar
Default Re: What are you guys using for oil return line? (Black R)
i bought a rubber hose thingy, it was pretty thick and used it as an oil return, got it at home depot
Old Feb 20, 2005 | 01:15 PM
Black R's Avatar
25 Year Member
Default Re: What are you guys using for oil return line? (orig1nalkhmersta)
what size/ markings?
Old Feb 20, 2005 | 01:31 PM
oxSLEEPERxo's Avatar
go to autozone or advance auto parts, get their thick *** fuel line, as long as it don't touch the downpipe you will be str8, or you can wrap that line with heat wrap
Old Feb 20, 2005 | 01:39 PM
alpha's Avatar
Fittings and lines from Flamenco-T
Old Feb 20, 2005 | 02:18 PM
Finland's Avatar
I use stainless braid hose and fittings from Earl's.
You can get it at any Parker Store (industrial supply)
I wouldn't trust my setup to some cheap **** rubber crap from home depot. Don't forget that the hose you use must be able to withstand close to 250F degree oil.
Old Feb 20, 2005 | 03:12 PM
platinum00's Avatar
Default Re: (Boondock Saint)
for your return line you want to use 10an at least. if your buying just the rubber hose then i think 10an is 5/8 inch. just make sure you get the high temp hose.
platinum.
jacob4lester
Feb 16, 2010 08:36 PM
MikeMAN
Apr 19, 2004 07:30 PM
beepy
Mar 1, 2004 09:26 PM
Diego Boost
Mar 10, 2003 01:20 PM
C1V1CS1
Oct 16, 2002 12:23 PM
