help with new turbo install
Old Feb 20, 2005 | 06:37 PM
Infinite Auto's Avatar
Default help with new turbo install
ok so a buddy put a homemade kit on his del-sol.....originally it was a oem b16 del sol, but bla bla it now has a jdm d15b vtec........he is using 450s, and a chipped ecu running uberdata i believe. he doesnt have a resistor box (lol my fault i forgot to tell him, im an ef guy).......he also doesnt have anything hooked up to the map sensor to hide boost.
his problem is the car wont rev past 3500, would this be because he doesnt have a resistor box? or cuz of the map sensor? or what other problems????????? i sold him the kit so i kinda wanna make it work....thanks!
Old Feb 20, 2005 | 06:40 PM
beepy's Avatar
Default Re: help with new turbo install (B18TurboEF)
You don't need to hide boost from Uberdata. So it must be your injectors.
Old Feb 20, 2005 | 07:17 PM
any other ideas??? just trying to figure this out, maybe the chip is bad???
Old Feb 20, 2005 | 08:04 PM
93turbo16's Avatar
sounds like a bad chip. Did he turn off the knock sensor.. what ecu? ETC... use a resistor box if you like your injector drivers.
Old Feb 20, 2005 | 08:08 PM
XSIintegra's Avatar
Default Re: help with new turbo install (93turbo16)
stock Map sensor? it can't read positive pressure. You don't have to hide it, but its not going to read it either.
Old Feb 20, 2005 | 08:44 PM
Default Re: help with new turbo install (XSIintegra)
i have no idea what ecu he is using, its obd1 running uberdata....if you can answer these questions that would be most helpful
1. does he need to do anything with the map sensor??? its the same as it was stock...
2. ill get the resistor box hooked up for him, but as of now could it be causing it to stop reving past 3500??
3. i was not there durring the install so is there anything else that comes to mind?
Old Feb 20, 2005 | 08:51 PM
Black Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSIintegra &raquo;</TD></TR><TR><TD CLASS="quote">stock Map sensor? it can't read positive pressure. .</TD></TR></TABLE>
yes it will
Old Feb 20, 2005 | 08:52 PM
Default Re: help with new turbo install (Black Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Si &raquo;</TD></TR><TR><TD CLASS="quote">
yes it will</TD></TR></TABLE>
ya i just read past that lol
Old Feb 20, 2005 | 08:53 PM
XSIintegra's Avatar
I'm not very familiar with Uberdata...is the car throwing a CEL? What happens near 3500rpms....as in, what does it do exactly or sound like? How long were the injectors in before the turbo/have they been run to redline w/o problem before the turbo? Time to invest in a good wideband A/F meter
Old Feb 20, 2005 | 08:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSIintegra &raquo;</TD></TR><TR><TD CLASS="quote">I'm not very familiar with Uberdata...is the car throwing a CEL? What happens near 3500rpms....as in, what does it do exactly or sound like? How long were the injectors in before the turbo/have they been run to redline w/o problem before the turbo? Time to invest in a good wideband A/F meter</TD></TR></TABLE>
i cant answer any of that for you, i havnt been a part of all of it, im just trying to get an idea of what people think to look for when i head over there tomorrow
Old Feb 20, 2005 | 09:03 PM
XSIintegra's Avatar
find out if it has a CEL and a stock MAP sensor
Old Feb 20, 2005 | 09:08 PM
well i said its a stock map, and yes they can read boost (hence a cel under boost) but again i dont know if its throwing codes
SeDA(9)n
Engine Management and Tuning
Oct 14, 2009 09:30 PM
zach1288
Jan 10, 2009 08:53 AM
RockinthEFhatch
Jun 15, 2007 12:53 AM
urbansi
Jun 8, 2005 05:39 PM
Teggyb18b
Dec 5, 2002 05:32 PM
