oil pan question d16y8
didnt know where to post this.....
i think i've read somewhere that like a 96-98 Y8 oil pan will not work with a 99-00, is this correct? i dont see why it wouldnt work, but i figured i'd find out before trading for one thats already drilled for oil return.
Re: oil pan question d16y8 (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">i would think it would fit because they are both y8s</TD></TR></TABLE>
thats what i think too, but i wanna make sure, otherwise its under the car 4 times that are unnecessary(sp?)
Re: oil pan question d16y8 (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">from what i heard the 96-00 pans are the same
the 92-95 will not fit.
platinum</TD></TR></TABLE>
This is what I thought as well.
Re: oil pan question d16y8 (RyanCivic2000)
Correct. Y8 pans are all the same (96-00). They're aluminum, the aluminum pan is the only one that will fit the y8 without modifing the oil pump and pickup.
Re: oil pan question d16y8 (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">Correct. Y8 pans are all the same (96-00). They're aluminum, the aluminum pan is the only one that will fit the y8 without modifing the oil pump and pickup.</TD></TR></TABLE>
actually I have been running a y7 oil pan on my y8 for almost a year. The only problem is that I can't use my flywheel dust cover without modification.
actually I have been running a y7 oil pan on my y8 for almost a year. The only problem is that I can't use my flywheel dust cover without modification. </TD></TR></TABLE>
The Y7 pan isn't aluminum?
this is what i was looking for, thanks. im not running a flywheel cover anyways, so either way i should be good.
i appreciate the help guys.
edit:
hit the wrong quote, SOHC_MShue's post is what i was trying to refer to...
edit:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">The Y7 pan isn't aluminum?</TD></TR></TABLE>
i don't think so. Its black unlike the y8 pan which is just aluminum metal in color.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic »</TD></TR><TR><TD CLASS="quote">this is what i was looking for, thanks. im not running a flywheel cover anyways, so either way i should be good.
no problem
no problem
no problem </TD></TR></TABLE>
That's correct. The y7 pan is not aluminum. And my del sol with a y8 came stock with the y7 pan as far as I know. Cause when I bought a tapped y8 pan off of here I was suprised that they were so different. But ya, the only major differences in the pans is the material obviously and the gaskets are different.
Re: oil pan question d16y8 (Happyman)
haha cool. Does your flywheel cover fit? Maybe if del sol's came stock with a y7 oilpan they have parts that will allow me to fit the flywheel cover on my y8 with that pan.
Na, I'm looking for a spare y7 or y8 pan tho if someone has one....I still have the tapped one on my car with no turbo lol.
when i replaced my oil pan on my 99 ex (after stupid honda dealership striped the drain plug threads). The pan was steel and the factory replacement was aluminum. hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman »</TD></TR><TR><TD CLASS="quote">Not at the monment but I can get some....you wanna trade? :-D </TD></TR></TABLE>
yea probably so. I'm just wondering if yours is tapped in a spot where it will easily hook up with my oil return.
nah its a custom kit. I have a barbed fitting on the pan now with a rubber line going to it from the turbo. Never had any problems with it so i haven't felt the need to upgrade to the fancy ss return line
92integraVTECgsr
08-05-2008 11:24 AM
MilanoRed EG6
07-20-2006 05:36 PM
