n00b turbo tech question
Old Feb 16, 2005 | 06:10 PM
Integra21's Avatar
Default n00b turbo tech question
:jumps into flame suite:
i have a blitz turbo controller and greddy turbo guages -
my question is why does it read a negative psi, BAR, etc when im completely off boost?
also why can it be at 0 when the turbo is obviously spooling and making power?
im a n00b to forced induction - throw me a freakin bone
just trying to learn
Old Feb 16, 2005 | 06:12 PM
93turbo16's Avatar
you are under vacuum when not boosting, and when it is at zero you are building boost...
Old Feb 16, 2005 | 06:14 PM
Integra21's Avatar
Default Re: (93turbo16)
can you elaborate please - thanks for the info
Old Feb 16, 2005 | 06:19 PM
BlueShadow's Avatar
Default Re: (Integra21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">can you elaborate please - thanks for the info</TD></TR></TABLE>
When you are at WOT (wide open throttle) what does your boost gauge read?
When you are just coasting around with very little throttle input you will be in vacuum because the turbo's aren't getting enough exhaust gas to spool them up. So it's just like your car was N/A, and you will be in vacuum. Once you start giving it more throttle input your turbo will spool faster until you go from high vacuum to low vacuum then eventually you start making boost (positive pressure aka. opposite of vacuum).
93turbo16's Avatar
when you aren't boosting... like an N/A car.. it will run about the same vacuum. The only difference is the turbo spools, and it creates positive pressure (boost). Like you can pull the inlet pipe off a honda and run it right off the TB, and you will get the same vacuum reading as if you had it connected to the turbo..
Just had to beat me to it...
Old Feb 16, 2005 | 06:22 PM
Integra21's Avatar
ok thanks guys - ay WOT the guage reads .5 (BAR i believe) its 7 psi- it says 7psi on my blitz turbo controller (SBC-ID)
Old Feb 16, 2005 | 06:24 PM
Integra21's Avatar
Default Re: n00b turbo tech question (Integra21)
so basically the turbo is spinning backwards? ??
Old Feb 16, 2005 | 06:25 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks guys - ay WOT the guage reads .5 (BAR i believe) its 7 psi- it says 7psi on my blitz turbo controller (SBC-ID)</TD></TR></TABLE>
Ok, just wanted to make sure nothing was wrong. But yah, the opposite of boost is vacuum. When you're not boosting (ie coasting, shifting) you'll be in vacuum.
Old Feb 16, 2005 | 06:26 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">so basically the turbo is spinning backwards? ??</TD></TR></TABLE>
No, it's not spinning backwards...it's just not spinning fast enough to pressurize the air.
Old Feb 16, 2005 | 06:27 PM
93turbo16's Avatar
haha, yea it spins back wards, and puses air out the filter back into the atmosphere.
Old Feb 16, 2005 | 06:28 PM
Integra21's Avatar
Default Re: n00b turbo tech question (BlueShadow)
ok thanks guys for answering my question - im sure ill come across some more down the road - thanks for now
rice a roni
May 18, 2006 07:01 PM
ablack934doorcivic
Jun 21, 2004 05:41 PM
crx1856
Aug 19, 2003 04:39 PM
integraty
Oct 8, 2002 03:31 PM
