plastic charge pipes or not?
Old Feb 20, 2005 | 05:53 PM
CRAZYHONDA's Avatar
Default plastic charge pipes or not?
can i use it for a while. until i get some for metal pipes for my smif. only gonna boost 5 psi no higher 8 psi with metal. just for a 1or2 month.
Old Feb 20, 2005 | 06:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: plastic charge pipes or not? (CRAZYHONDA)
you can, i mean hell ford uses plastic side tanks on their intercoolers. i dont know how good or bad they dissipate heat but in a pinch you should be ok.
Old Feb 20, 2005 | 06:37 PM
CRAZYHONDA's Avatar
Default Re: plastic charge pipes or not? (boostedcivicsir)
yea, most stock turbo car use plastic.i'm just using a t25 turbo
Old Feb 20, 2005 | 06:42 PM
beepy's Avatar
Assuming that they stay away from the manifold or exhaust, plastic is superior to metal. Even "high boost" isn't very much pressure when you think about it. The pressure the PVC pipes under your sink must endure is much higher.
Old Feb 20, 2005 | 07:31 PM
h22 civic's Avatar
Default Re: plastic charge pipes or not? (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Assuming that they stay away from the manifold or exhaust, plastic is superior to metal. Even "high boost" isn't very much pressure when you think about it. The pressure the PVC pipes under your sink must endure is much higher.</TD></TR></TABLE>
ive put 100 psi to those pvc pipes onder your sink
mrx
Jul 30, 2007 12:39 PM
civickid03
Apr 12, 2007 11:27 AM
vwandhondaboy
Jul 22, 2005 08:29 AM
1.8T_EG
Jul 21, 2003 05:01 PM
