ls vtec turbo oil leak--help needed!!!!
Leak is coming from the G.E. adapter where oil filter goes..
leak only occurs when the engine is under a load
the leak is coming from the filter side NOT the block side
(its not the filter/gasket etc..)
--I thought it was a defective adapter so I bought a brand new one.
Still leaking.....Is it possbile the I have too much oil pressure?
Ihave yet to hook up a gauge so i have no readings to tell you
(i know that is my next step)
I did use the gsr oil pump--
anyone ls vtec turbo using gsr oil pump??
This isnt an all of a sudden leak, the motor was just installed and has been leaking ever since. 97ls block-98gsr head
any advice would be greatly appreciated!!
Re: ls vtec turbo oil leak--help needed!!!! (Napoleon Dynamite)
no---its leaking on the oil filter side of adapter and only under load (boost)
plz guys--need your help/info!!!!
Re: (PrettyLude)
no catch can installed...doesnt leak at idle--can let sit for an hour and wont leak...
I'll drive for it for 5 mins...put back on lift and is leaking...whether I boost or not...
Im going to try and bypass the adapter and just run line to head from oil pressure switch...hopefully that will solve it...
any other suggestions?????????
vtecb20coupe
12-03-2004 09:19 AM
