Precision Turbo
Old Feb 18, 2005 | 03:58 AM
93H22ACX's Avatar
Default Precision Turbo
Here is the spec for this turbo i bought from a friend to run in my H22 hatch.
What do you think of this turbo's max hp output with the smaller T350 turbine wheel?
PT67 (6752s) is a 67mm inducer compressor wheel with a 76 trim T350 turbine wheel .68a/r.
Here's the pics:
Modified by 93H22ACX at 8:39 AM 2/18/2005
Modified by 93H22ACX at 8:44 AM 2/18/2005
Old Feb 18, 2005 | 04:27 AM
MidShipCivic's Avatar
Damn if only turbos were edible...
Old Feb 18, 2005 | 04:38 AM
Turbowa's Avatar
Default Re: Precision Turbo (93H22ACX)
A real work of art
Old Feb 18, 2005 | 04:55 AM
CXHATCHver2.2's Avatar
Default Re: Precision Turbo (Turbowa)
thats a mean lookin ****
edit: most likely with the size 600-650hp
Old Feb 18, 2005 | 06:03 AM
TheShodan's Avatar
Moderator
Default Re: Precision Turbo (CXHATCHver2.2)
I measured a couple of these before, when we played "guess my turbo" in the shop. It was this VERY one, and was good to about 750crank hp or so..
Old Feb 18, 2005 | 06:57 AM
Rod Short's Avatar
Default Re: Precision Turbo (TheShodan)
Guys,
The turbo pictured is actually a 6152 with a T04S cover and a T4 exhaust side. We scribe numbers on the compressor cover outlet to I.D. what the turbo is. Someone has changed the "1" to a "7" and misrepresented what this is.
We've never made a turbo with wheel combination like this. We believe that, in this case, the turbine wheel si way too small to drive that big of a compressor wheel.
We spoken by phone with the person who now owns the turbo and our understanding is that this piece has passed thru a number of hands before it got to its present owner. He is going back to the person that he got this from. If that doesn't work out, we've offered to try to work something out to try to help him as well.
Just wanted to clear this situation up.
Rod Short
Sales Manager
Precision Turbo
Old Feb 18, 2005 | 07:01 AM
93H22ACX's Avatar
Default Re: Precision Turbo (Rod Short)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod Short &raquo;</TD></TR><TR><TD CLASS="quote">Guys,
Rod Short
Sales Manager
Precision Turbo</TD></TR></TABLE>
That would be me (current owner).
talked to my friend and he said he is going to square things away. everything will be okay
i appreciate what you and patrick are doing for me. GREAT SERVICE!!!
Modified by 93H22ACX at 1:27 PM 2/18/2005
Old Feb 18, 2005 | 07:03 AM
Arturbo's Avatar
Better than steak
25 Year Member
You can also tell by the shape of the blades its not a 67mm compressor wheel. Its definatly a pt61. Not a bad turbo tho. One of my favorites.
Old Feb 18, 2005 | 07:05 AM
93H22ACX's Avatar
Default Re: Precision Turbo (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">You can also tell by the shape of the blades its not a 67mm compressor wheel. Its definatly a pt61. Not a bad turbo tho. One of my favorites.</TD></TR></TABLE>
it is a good turbo but i need more power
pauld
May 23, 2007 10:31 PM
booscivic
Sep 25, 2006 07:50 PM
Dammit_Dan_954
Mar 5, 2006 12:02 AM
DUB20VT
Mar 11, 2005 06:56 AM
fernancivic
Dec 30, 2004 07:51 AM
