D17A2-T question
Old Feb 18, 2005 | 06:37 PM
20psi17c's Avatar
Default D17A2-T question
Ok where are some sites I can find a turbo kit for a buddies 01 D17A2 engine? We dont want alot of power, looking to make 200+. Ive only seen 1 kit so far.
I figure I could make him a kit, Manifold, Turbo, Downpipe, and intercooler. I just dont see where i could put the oil feed and return line and water feed and return lines... Is it possible to slap a 14 or t25 on this engine and run no fuel management?
Old Feb 18, 2005 | 06:38 PM
cox5t's Avatar
Default Re: D17A2-T question (20psi17c)
check out exoticperformanceplus.com they have a nice kit for your car
Old Feb 18, 2005 | 06:41 PM
20psi17c's Avatar
Thanks, know anymore? maybe little cheaper?
Old Feb 18, 2005 | 07:18 PM
Drew Peacock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20psi17c &raquo;</TD></TR><TR><TD CLASS="quote">Ok where are some sites I can find a turbo kit for a buddies 01 D17A2 engine? We dont want alot of power, looking to make 200+. Ive only seen 1 kit so far.
I figure I could make him a kit, Manifold, Turbo, Downpipe, and intercooler. I just dont see where i could put the oil feed and return line and water feed and return lines... Is it possible to slap a 14 or t25 on this engine and run no fuel management?</TD></TR></TABLE> LOL yes it possible to run no engine management you will just blow your engine, an oil line you can run off the back of the block oil pressor switch just use an adapter. water feed bypass the throttle body coolant and use that. You will have to tap the sump and make a return line.
kauai96
Jun 1, 2008 06:31 PM
EG6_LOVER
Aug 6, 2007 06:44 PM
slamedcivic
Sep 19, 2006 05:55 PM
GSR95T
Jul 3, 2003 10:45 AM
OEMJDM
Jan 21, 2003 03:37 PM
