Head + Manifold = Problems????
Old Feb 20, 2005 | 07:39 PM
STL01Civic's Avatar
Default Head + Manifold = Problems????
recently I just notice something. One of the bolt came off my HKS manifold. I inspect and try to replace it. The bolt just keep turning and it won't be tighing. I mean it just turn and turn (I can remove that bolt with my hand right now).
Could it be stripped???
Any help would be great.
Old Feb 20, 2005 | 07:44 PM
underpressure02's Avatar
Default Re: Head + Manifold = Problems???? (STL01Civic)
yeah if you can pull it out or it just keeps turning it is prob stripped. You sure your using the right size bolt?
XSIintegra's Avatar
You guessed it. Just throw a Heli-Coil in it and go easy on the Aluminum when your torquing your bolts and nuts down.
Old Feb 20, 2005 | 08:15 PM
STL01Civic's Avatar
Default Re: Head + Manifold = Problems???? (XSIintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">yeah if you can pull it out or it just keeps turning it is prob stripped. You sure your using the right size bolt?</TD></TR></TABLE>
I know it is the right size. I got those from Honda Parts dept.
How does the Heli-Coil works???
Right now I am thinking about replace the head, nippon leakless gasket, and ARP Head Stud.
Or
Should I bring it to the shop to see if they can fix it.
Old Feb 21, 2005 | 04:40 AM
grndcont's Avatar
dude, just get a helicoil kit. the same thing happend to me, use the kit right and you'll be fine. plus it's like 25 bucks and takes an hour.
Old Feb 21, 2005 | 08:52 AM
Corinthians's Avatar
Default Re: (grndcont)
or filled up with exposy (the 2 thing mixed together) and drill hole after it fills up and harden
Old Feb 21, 2005 | 08:59 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STL01Civic &raquo;</TD></TR><TR><TD CLASS="quote">
Or
Should I bring it to the shop to see if they can fix it.</TD></TR></TABLE>
If you're going the ARP route, you'll probably be checking your head for square and having it resurfaced if necessary. While the head is at the shop, have the guys throw a TimeSert in where the stripped hole is. Just make sure they don't drill too far and puncture an oil/coolant passage or combustion chamber.
Old Feb 21, 2005 | 09:01 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Head + Manifold = Problems???? (DaX)
I'm with DaX, Timeserts are much better. Sure, they cost a little more but they work a whole lot better
Old Feb 21, 2005 | 09:30 AM
STL01Civic's Avatar
Default Re: Head + Manifold = Problems???? (wantboost)
alright I am going to give the HeliCoil a try.
anybody which one is it i need? or if you a link directly let me know.
http://www.thetoolwarehouse.net/shop/TTW410.html
jdm009
Jul 11, 2014 11:58 PM
JSpekBB4
Jan 22, 2007 10:27 PM
DC2 to AP2
Acura TL, RL & ZDX
Nov 19, 2005 06:37 PM
accordfreak
Apr 22, 2003 01:37 PM
GrandMarkie
May 17, 2002 12:53 PM
