Turbo Help???
Old Feb 17, 2005 | 11:44 AM
97_hatch's Avatar
Default Turbo Help???
Just got a question, Im going to be running a turbo set up in my 92 dx
on a gsr motor. But when the setup was in the gsr itself it kind of ran poorly in the
end. In the beginning it ran perfect. My friends said that they either had to take off the map sensor or get one because we didn’t have the apexi turbo controller. If I just run the setup without that apexi controller should it be able to run fine. And would I need some different injecters too?
Thanks..
Old Feb 17, 2005 | 11:50 AM
Boosted RSX-S's Avatar
Default Re: Turbo Help??? (pssshhh_01)
sounds like u got an electronics or wiring problem.....what exactly is it doing?
Old Feb 17, 2005 | 11:54 AM
97_hatch's Avatar
Default Re: Turbo Help??? (Boosted RSX-S)
It feels like it's losing pressure. it Chokes and sometimes bogs out. If you slam the pedal down It bogs then in higher RPM it runs a little more decent. I was told If I had the Apexi controller it would be able to help control all the air/fuel and the turbo without having to unplug the map sensor where the engine light would go on..
Old Feb 17, 2005 | 12:33 PM
92b16aTurbo's Avatar
Sounds like you're running rich. What are you using for engine management? I would suggest Hondata, AEM, or Uberdata.
stopsayingJDM
Aug 13, 2012 04:19 PM
sparky2pipes
Engine Management and Tuning
Jul 11, 2011 07:46 PM
team_lunatics
13
Oct 6, 2008 09:56 AM
mpxs20
Nov 10, 2005 08:10 AM
