just boosted my b18c.. backfiring problem..
Old Feb 17, 2005 | 11:20 PM
92eh3si's Avatar
Default just boosted my b18c.. backfiring problem..
aite.. i just got done installing my turbo on b18c and it is backfiring..
here is the set up:
stock b18c
turbonetic t3-t4
runnin walbro 255 with B&M FPR and gauge
fuelp pressure set at 41~42 wit vacuum off
regapped my ngk spark plugs
runnin dsm 450's
exhaust not hookedup, running open dp
it backfires about 5500~6000 rpm
no boost control and only boost gauge hooked up ( need to get some gauges)
not sure where the timing is set right now.. i am assuming that's the problem..
NOT running FMU or Missinlink.. went with Uberdata with p72
also running hella rich right now..
can anybody think of why it is backfiring besides the timing being off?
please help me out..
Modified by 92eh3si at 8:34 AM 2/18/2005
Modified by 92eh3si at 8:55 AM 2/18/2005
Old Feb 18, 2005 | 09:06 AM
92eh3si's Avatar
Default Re: just boosted my b18c.. backfiring problem.. (92eh3si)
ttt
Old Feb 18, 2005 | 10:19 AM
Civicman86's Avatar
Running to rich maybe? Check all the exhuast seals to make sure they arent leaking anywhere?
Old Feb 18, 2005 | 11:38 AM
dustin's Avatar
So you have no tuning, no wideband, incorrect static timing ... and you wonder why the car is not running correctly?
I would try fixing these things:
1) Set the timing
2) Tune the car
Old Feb 18, 2005 | 12:28 PM
s2kdre's Avatar
Default Re: just boosted my b18c.. backfiring problem.. (dustin)
its flooding the motor at topend, timing is not going to make it backfire.
Old Feb 18, 2005 | 12:44 PM
dustin's Avatar
Default Re: just boosted my b18c.. backfiring problem.. (jdmhonda)
Sure it could. Either way this guy should fix his car.
"I poured sand in my engine and now it is not running right. Anyone know what the problem could be?"
Old Feb 19, 2005 | 12:32 AM
VspecSiR's Avatar
i had a similar problem, turned out to be map sensor signal
Old Feb 19, 2005 | 06:32 PM
Nameless RB26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">its flooding the motor at topend, timing is not going to make it backfire.</TD></TR></TABLE>
We fixed the problem by setting the timing to 16 degrees today. Thanks for your knowledge.
ekcivic2
Dec 21, 2023 06:02 AM
cslegacy
Mar 30, 2009 11:10 PM
9WON4
Jun 11, 2006 07:42 AM
jonyb
Apr 18, 2006 08:28 AM
APZGSR
Mar 3, 2003 06:53 PM
