help me with 1gen dsm bov with the stock pipe, wat u use to put on ur TB
i have a 1gen dsm bov with the stock metal pipe. its hella small compare to the d16z6 tb. wat can i use to mount it to my TB. i tried searching but no luck and i did search hard.
thanks in advance
thanks in advance
Re: (SOHC_MShue)
Or mine:
The flange I got was cast iron bonded to a steel pipe, so I just cut an arc of the pipe off and welded that into the larger charge pipes.
